logicaluk
Mar 30, 2017 10:19:55 GMT
I'm in the prosses of rebuilding my acclaim a car mostly made of unobtainable bits now. the anti roll bar also acts as the control arm so new bushes would be a really good idea, ive found the arb to suspension arm bush a super pro part Spf1642k for 56 quid (ouch) but no joy on the arb mounting. Any help will be greatly appreciated. Dan.
heathrobinson
Broken everything
Club RR Member Number: 111
Mar 30, 2017 10:37:50 GMT
Have you considered the liquid polyurethane kits? You mix it up, pour it in, and hey presto. Not sure if you could make it work with that kind of convoluted shape, but I thought it worth mentioning. Hope that helps
logicaluk
Mar 30, 2017 13:19:10 GMT
Yep making moulds and cast my own is going to be the last resort. Just hoped i wouldn't have to.
steveg
Mar 30, 2017 15:20:43 GMT
Is anything from Honda available, expect you have tried Rimmers etc.
Mar 30, 2017 21:27:13 GMT
These are still listed on FPS parts catalogue for the Triumph Acclaim but maybe no stock, I would be happy to make enquiries for you. Part image for FSK6283 FIRST LINE Susp/Control/Wishbone/Arm Bush/Mount (FR LH+RH) Product No: FSK6283 Unit: Each Triumph Acclaim 1.3 - Saloon - Part fitment dates 01/82-06/84 1335cc, 4 cyl, OHC cam, 8v These are about £5 each if I can get them. I also have loads of new old stock bushes down in our basement which I will have a look at when I get the chance. What was the Honda equivalent called as they don't list the Acclaim apart from as a Triumph. It may also be worth giving Mark at APM Duraflex a call as he custom makes polybushes. Don't know if he could help but maybe worth a call.0161 773 1730 faceache link website link
Last Edit: Mar 30, 2017 21:29:53 GMT by Rebuilda
1988 DUTTON LEGERRA MK1 - SPARES DONOR 1989 DUTTON LEGERRA MK2 - CURRENT PROJECT 1990 DUTTON LEGERRA ZS MK2 1990 DUTTON LEGERRA ZS MK2 DUTTON PHAETON S2 - Resting DUTTON PHAETON S4 - Resting DUTTON PHAETON S4 - PROJECT X DUTTON SIERRA S2 - Resting
steveg
Mar 30, 2017 23:00:03 GMT
The Honda version was called the Ballade.
logicaluk
Cheers rebuilda that looks like an inner bush. I believe they were common to th rover 200 and mk3,4 and 5 civic.
Ill try to give APM a call next week.
Dan
ferny
Club RR Member Number: 13
Might be worth trying collectors car parts Heathrow on the off chance .
Might be worth trying collectors car parts Heathrow on the off chance . Didn't they close down last year? Thought everything went to Auction?
Don't know I have not been there for years.
logicaluk
Thanks guys ive order the arb to suspension arm bushes. And looks like ill end up casting a set of arb mounts. Cheers Dan
I had a root around down in the basement and drew a blank but did find a whole box of mk345 cortina void bushes Do you have a vacuum tank or bag to get the air bubbles out of the mixture?
Last Edit: Apr 7, 2017 7:32:41 GMT by Rebuilda
