Rear axle choice Deleted
@Deleted
Mar 23, 2017 17:40:52 GMT
Ive been googling but thought id ask here as there is a good broad knowledge base here.
Right. I'm looking for:
A rwd rear axle with drums brakes capeable of about 150bhp max.
Has to be easy to get hold of here and off the shelf brake parts, bearings etc.
Option to take 16" steels.
Approx 57" wheel mounting surface to wheel mounting surface.
Lsd would be nice.
Stud pattern not important.
Cheap.
Any help appreciated with what vehicle it may come from.
Mar 23, 2017 19:03:35 GMT
Volvo 940 rear axle is strong,discs with internal drums,57" ish,will take 16" wheels and if your lucky come with a eaton g80 locking diff.
@Deleted
Mar 23, 2017 19:33:23 GMT
Thanks osm, thats almost perfect, unfortunatley i have to have drums though.
93fxdl
Enter your message here...
Scimitar axle? Don't know the width unfortunately, but parts easily available and a jag lsd can be fitted and its drum braked Ttfn Glenn
gavs1
Transit axle?
chrismc
Yorkshire and The Humber
www.redhouseclassics.com
Mar 24, 2017 12:18:03 GMT
Scimitar axle? Don't know the width unfortunately, but parts easily available and a jag lsd can be fitted and its drum braked Ttfn Glenn Scimitar SE5 axle, 54" Scimitar SE6 axle, 56" Powerlok LSD fits but it's a heavy old lump of an axle.
Have a look at my restoration blog...www.redhouseclassics.com
Mar 24, 2017 12:24:15 GMT
If it's going into the truck in your avatar, how about a Mazda B2500 axle? Apparently they're based on the Ford 8.8" axle, so plenty tuff. The stock ratio is 3.7:1, but if they are 8.8"-based then alternatives are readily available.
Badger
Mar 24, 2017 13:09:34 GMT
Dolomite Axle? All of those have drums on the rear, Sprint one can apparently handle 200ish HP so you should be good on that front. May be a bit narrow for you at at about 53" though... apparently the TR7 axle (which is pretty similar) is a couple of inches wider than that, so may be about right for you.
@Deleted
Mar 24, 2017 13:21:33 GMT
Thanks chaps, all good ideas thankyou. Scimitar se6 sounds good, and il have a search around for more info on the other sugestions.
Darkspeed
Club RR Member Number: 39
Rear axle choice Darkspeed
@darkspeed
Club Retro Rides Member 39
Mar 24, 2017 17:51:32 GMT
Rover SD1 may fit the bill
Last Edit: Mar 24, 2017 17:52:06 GMT by Darkspeed
kevfromwales
the conrod's REALLY out the block now!
Mar 24, 2017 18:37:58 GMT
Ldv pilot, but might be a bit wide. Taxi steels will fit the pcd and are sixteens. Also toyota lucida, us ford pattern, and cheap as chips
Can check both of those widths over the weekend if i remember
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
@Deleted
Mar 24, 2017 19:35:22 GMT
Ldv pilot, but might be a bit wide. Taxi steels will fit the pcd and are sixteens. Also toyota lucida, us ford pattern, and cheap as chips Can check both of those widths over the weekend if i remember OOOhhh yes please, that would a tremendous help if you can remember to run a tape across those 2 axles, are they fitted to your vehicles or are they up for grabs? Il have a look at SD1, thanks.
Last Edit: Mar 24, 2017 19:37:23 GMT by Deleted
kevfromwales
Mar 24, 2017 19:41:41 GMT
I have at least one ldv axle up for grabs, probably the toyota too. Will check
