Mar 18, 2017 14:03:30 GMT
I've fitted a rather nice electrically adjusted and heated seat into my van from a Renault Laguna 2. Luckily it's in aprox the right position for me but I would to be able to adjust it. It looks like there is some type of ECU strapped under the seat but I don't really want to power it up incase I fire the seat airbags by mistake as I have no idea on colour coding etc I've tried feeding 12v to the motor but nothing happened? Does it need a PWM driver or some such trickery? Is it likely to need a controller for the seat heating too?
squonk
Mar 19, 2017 11:34:00 GMT
I have a 2007 Laguna 2. I am led to believe that all of the electrics are on a CAN BUS with various ECU's for different functions coded to and talking to each other. I suspect the box under the seat is the 'out station' that takes the CAN messages and produces control functions from them. In which case your chances of making that box work are practically zero!!
I would pull off one of the motors and have a play with it on the bench - it should work when powered by a suitable high current 12v supply. Then you will have to make up your own control circuitry to get the seat functions to work.
fad
Mar 19, 2017 11:57:46 GMT
I have a 2007 Laguna 2. I am led to believe that all of the electrics are on a CAN BUS with various ECU's for different functions coded to and talking to each other. I suspect the box under the seat is the 'out station' that takes the CAN messages and produces control functions from them. In which case your chances of making that box work are practically zero!! I would pull off one of the motors and have a play with it on the bench - it should work when powered by a suitable high current 12v supply. Then you will have to make up your own control circuitry to get the seat functions to work. This. You've no chance of emulating can bus protocols. Get at the live on the motor and use relays and your own switch panel.
Mar 19, 2017 14:45:27 GMT
I've tried a direct feed from a 12v battery to the motor with no result?
fad
Mar 19, 2017 15:15:23 GMT
Is there just a pair of wires on the motor?
Mar 19, 2017 15:22:16 GMT
Mar 19, 2017 17:23:18 GMT
Just to throw a spanner in the works, isn't an adjustable seat now part of an MOT?
Mar 19, 2017 18:55:57 GMT
Just to throw a spanner in the works, isn't an adjustable seat now part of an MOT? No just required to be securely fixed and not obviously defective Is there just a pair of wires on the motor? Yes just the 2 wires which was why I was surprised it didn't work
Last Edit: Mar 19, 2017 19:01:28 GMT by dodgerover
fad
Mar 19, 2017 19:05:34 GMT
One is a live, one a switched live, earthed through the case? Or one clockwise, one anti clockwise, earthed through case?
Last Edit: Mar 19, 2017 20:10:46 GMT by fad
squonk
Mar 19, 2017 19:06:35 GMT
This is a circuit I put together to replace a faulty seat controller on a Range Rover. You should be able to adapt it easily for your seats:
fad
Mar 19, 2017 20:09:48 GMT
Not till he works out how to make the motor move he can't.
Mar 19, 2017 20:23:43 GMT
it'll be the same as a window motor, so if you want to move it you need to give it an earth as well as a live, very easy.
squonk
Mar 19, 2017 21:02:06 GMT
Not till he works out how to make the motor move he can't. Thanks for pointing that out, I had no idea dodgerover: do you have a multimeter? Check the resistace of the motor. It will probably be somewhere between 2 ohms and 15 ohms depending on the motor design. If the resistance falls somewhere in this range the motor is probably Ok. Presumably its connected to some kind of reduction gearbox? Possibly this has siezed.
fad
Mar 19, 2017 21:04:26 GMT
Not till he works out how to make the motor move he can't. Thanks for pointing that out, I had no idea Cant work out if I have upset you there or not?
squonk
Mar 19, 2017 21:26:53 GMT
No, not at all - just me being sarcastic!!!
Sorry!
Mar 19, 2017 21:41:11 GMT
it'll be the same as a window motor, so if you want to move it you need to give it an earth as well as a live, very easy. I tried a +ve and -ve feed to the wires coming out of the motor, I didn't think of trying an earth to the body
fad
Mar 19, 2017 21:42:13 GMT
it'll be the same as a window motor, so if you want to move it you need to give it an earth as well as a live, very easy. I tried a +ve and -ve feed to the wires coming out of the motor, I didn't think of trying an earth to the body Thats what I meant up there ^^^
Mar 20, 2017 11:56:15 GMT
Just to throw a spanner in the works, isn't an adjustable seat now part of an MOT? No just required to be securely fixed and not obviously defective Is there just a pair of wires on the motor? Yes just the 2 wires which was why I was surprised it didn't work Not so - My P100 failed it's 1st MOT when I finished building it as the seat could not be adjusted forward or back. (I used modded Cossie runners) It was the only failure point too. When I questioned it, he said that some wouldn't fail it but should. I changed the runners over to a proper P100 one and it sailed through.
Mar 20, 2017 13:30:07 GMT
Yep you are right, not come across that before. Reason for rejection The driver’s seat fore and aft adjustment mechanism not functioning as intended.
However it says specialist modifications to be accepted so I also read that as: if presented with no method of adjustment, ie switches removed or bucket seats bolted in position it would be pass and advise, I'm sure one of the testers on here could give us their take.
Luckily it was tested just before I fitted it and it's mounted on the van runners so just the recline function is motor driven on mine.
Last Edit: Mar 20, 2017 13:31:34 GMT by dodgerover
Mar 21, 2017 15:08:39 GMT
Sorry didn't mean to cause you more grief!
