compass
www.compasstrading.co.uk
Mar 10, 2017 19:49:29 GMT
I'm after some options on a B235r engine conversion please.
I currently drive a Saab 9-5 estate with the 2.2 Tid engine in it. My dad bought this new, and passed it down to me a while ago now. The problem is in really don't like the 2.2 diesel engine. It's slow, noisy and not even that good on fuel. I 've has a few aero's in the past, and break a lot too, so have good access to the engines and parts
The question is though, what's the best route to achieve around 300-350 bhp? 250 bhp as standard, so not a huge hike, but want to make a good strong engine. Guessing cams, bigger turbo, exhaust and maybe injectors?
The swap itself shouldnt be an issue. The mounts look to be the same, so it should slot in easy enough. Guessing I'll need to use the loom and ECU off the donar car, and get a high pressure fuel pump. Am I missing anything abvious?
Basically, I'm wanting to make a bit of a daily sleeper! Any help appreciated.
Mar 10, 2017 23:46:58 GMT
The maptun site gives a good idea of what is required for each stage.
I'm not an expert on the B2*5 but basically 290bhp/430nm can be had from a 3" down pipe, 3.5bar fpr and a remap
300bhp/440nm can be had from the above with an uprated IC
After this it gets expensive, a TD04-18 or 19t and injectors gets you 320bhp but torque needs to be limited to 450nm still. This is the limit of the B2*5 internals. From here you will need forged internals or a b234 bottom end to make a. B234/5 hybrid.
I believe the B2*5 head breathes slightly better but both are capable of big bhp without modification. The B2*4 cams will give you a bit more top end but lose out in the mid range, B2*5 cams give better driveability but are less peaky. Splashing out on Maptun/Abbott cams at this stage would be considered a waste and unnecessary. The general consensus is an LSD is the best modification you can do once once you get past 300bhp but thats £1k. The standard clutch in good condition will just about take the 450nm.
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
Mar 10, 2017 23:52:05 GMT
For remapping go to Saabnoob (Noobtune) on UKSaabs. In fact go there for advice. Very friendly and hugely knowledgeable bunch.
Not sure what equipment the 2.2 came with but I would imagine you'll want an Eibach/Bilstein B12 kit, bigger brakes from the Aero or 9-3, a smattering of poly bushes and some decent rubber before you go making a B235r any quicker.
A Hirsch ecu gives 300bhp/400nm with no hardware changes.
With that torque figure it would seem the map is reigned in so that standard hardware can live, but even that doesn't seem right. The OEM downpipe will be at its limit at 260/270. I also can't see anything on the Hirsch site that's available for the 9-5 Aero and they don't list detail of previously available maps. From the maptun site www.maptunparts.com/tuning-kits/saab-9-5/2004/23t-aero-230-250-hp-2000-2005/mt5/173Stage 3 285bhp/440nm Remap Air filter 3.5bar FPR Exhaust Stage 4 315bhp/450nm Above plus... TD04HL-XT IC 465cc injectors Fuel rail spacers Cobra intake pipe
Mine is a 2006 so already on the big cobra pipe, the hirsch figures are 315ps and 400nm. They are notoriously over the 260bhp mark when on the rollers standard anyway.
compass
Mar 11, 2017 10:38:22 GMT
Cheers guys. Its more or less what I expected, as knew the internals of the 235/205 was never as strong as the 234/204. On the plus side, it seems relatively cheap to get to the 280-300bhp mark, which would be adequate for now, I'm sure!
Suspension will definitely need sorting, as its still on its original shockers and springs after 160k!
paul99
Mar 11, 2017 11:58:43 GMT
Plenty of knowledge about the B235 on UKSaabs, but can't help thinking you're making extra work for yourself starting from the TiD, unless it has particular sentimental value? Petrol 2.3's are cheap enough these days....
Mar 11, 2017 12:45:51 GMT
If you're just going for the pretty marginal upgrade to 300bhp then they're pretty bomb proof, they do like a coil pack now and then and are very fussy when it comes to spark plugs.
compass
Mar 11, 2017 12:55:41 GMT
Yeah, I know the aero's are dirt cheap to buy, but my Dad bought this new, and gave it to me so would like to keep hold of it. Not really sentimental, just be nice to keep this one! Plus, unless I'm missing something, it'll be a simple job, probably done over a weekend.
I break quite a few too, so will always have the di cartridges in stock, and most other parts.
compass
Mar 11, 2017 19:12:26 GMT
I seem to have spent the day convincing myself that it makes more sense to fit a B234 bottom end to the B235 head before I fit the engine to the car! Saves taking the engine out again further down the line!
Pretty sure 300bhp would be adequate, but I always seem to want more. The question is, with the B234 bottom end, and 18T turbo with associated mods, would it make it too much to use as,a daily? I'm in no major rush to do it, but if I'm spending upwards of £2/3000 on parts and software upgrades, I'd rather start the collection now!
Mar 11, 2017 19:23:06 GMT
I'd go HX35 over the 18T if you're going that far. If you're stripping the bottom end then go for PEC rods or similar so it's all brand new - that would be the plan for mine if SWMBO didn't drive it a fair bit.
