RobinJI
Following on from my last post, the tame local fabricator (Hayman of 'Hermfab') had a chance to bend my other bits up, so I now have all the tubes that should need bending sorted, meaning my time and effort's the only thing between me and a finished cage Hayman's done a great job of bending it all to my measurements, so providing I haven't cocked anything up, it should result in a nicely fitting cage. Top to bottom this lot consists of: Upper door bars, lower door bars, A-pillar supports & roof X bracing (one of which will need chopping in half) I quickly mocked up the door area: I noticed the doors don't even have any factory side impact bars in them, so I'll feel a lot safer in the car with this lot in there! While Hayman was doing his thing with the tubes I made a start on the mountings the rear legs will land onto. The fuel filler's in a really annoying place for a cage. I wasn't happy with how steep the rear legs would end up if I landed them in front of it, and running them right back behind it gets them too far behind the rear axle for my liking. (reducing rear crumple zone as well as taking up valuable wheel-carrying boot space.) To get around this a lot of cages for 924/44's seem to land the legs onto the inner wheel arch, but due to the torsion bar back end, this is only a single skin tub, without much structure as all the suspension loads are dealt with lower in the shell. So I've built a 'tower' out of 3mm plate that protrudes inboard from the arch tub and ties down to the boot floor directly above the shock mounts. (which as I plan to ditch the torsion bars in favor of a coil-over set-up, could do with some added strength.) And with the cover for the filler neck in place:
Last Edit: Nov 24, 2017 22:22:38 GMT by RobinJI
Oct 19, 2017 14:29:00 GMT
nice solution, we had creo up until 4 years ago, it's all solidworks now, but very similar modelling strategies
Oct 19, 2017 20:28:16 GMT
Have a great fondness for the 924, spent a couple of years crewing for a lad who ended up at the pointy end of PCGB/BRSCC 924 many years ago
As such I know all about removing underseal from a 924 shell, thankfully we never had quite those rot issues. That said we did strip a couple of crispier bodies. Really tidy work, think I recall a few of your earlier projects and the quality being of a high standard.
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
scimjim
Club RR Member Number: 8
While Hayman was doing his thing with the tubes I made a start on the mountings the rear legs will land onto. The fuel filler's in a really annoying place for a cage. I wasn't happy with how steep the rear legs would end up if I landed them in front of it, and running them right back behind it gets them too far behind the rear axle for my liking. (reducing rear crumple zone as well as taking up valuable wheel-carrying boot space.) If you’re future-proofing it, MSA regs don’t allow rear stays to be mounted further back than the rear suspension mounts - unless it’s needed to achieve the 30 deg minimum angle.
RobinJI
Oct 20, 2017 13:26:05 GMT
Thanks guys. If you’re future-proofing it, MSA regs don’t allow rear stays to be mounted further back than the rear suspension mounts - unless it’s needed to achieve the 30 deg minimum angle. Very good point. For some reason I got a bit confused over this. I had it in my head that it was the case, but when I looked quickly at the MSA yearbook while looking at the car and thinking what the best solution might be, I couldn't find it in there. Looking again now it's definitely there clear as day! It's lucky I did it this way! Just as a minor note, the regs say "ROPS must not extend beyond the front upper or rear suspension mounting points of the vehicle." I'm not sure exactly what on the 924 (or a lot of other cars for that matter) would be classed as the 'rear suspensions mounting point'. The rear beam has a series of 3 mounts down each side, with the rear-most one behind the axle line. On a leaf sprung car could you go as far back as the rear spring shackles!? It doesn't matter much to me, where I've put it is in front of the axle line, and in line with the rear shock (which passes in front of the drive-shaft), but it's an interesting ambiguity all the same.
Last Edit: Oct 20, 2017 13:27:35 GMT by RobinJI
Oct 20, 2017 18:02:45 GMT
Historically the back stays used to mount on the rear arches but if rules have changed it might be it's not possible to make the angle?
ade36
Oct 20, 2017 19:27:35 GMT
Really like that rotisserie. Is it shop bought or something you fabbed up?
RobinJI
Oct 25, 2017 10:13:02 GMT
Historically the back stays used to mount on the rear arches but if rules have changed it might be it's not possible to make the angle? It would be possible for the rules, the angle would be much the same that mine will end up at, I just thought it wouldn't hurt to add some more structure, as the 924 has no structural turret at the rear arch, so the arch is just a single skin of sheet metal. Really like that rotisserie. Is it shop bought or something you fabbed up? Thanks. The rotisserie is all home made. It's done me well so far but as the car's getting a little top heavy with the cage, I think I need to sort out a better way of locking its position than the current pinch-bolt arrangement. No progress to report, but I'm hoping to get an evening on it later today.
Last Edit: Oct 25, 2017 10:13:25 GMT by RobinJI
RobinJI
Tubes! I'm almost ready to drop the cage down in the shell and seam weld up all these joints, I've just got the diagonal braces between the door-hoops and the B-pillar to cut and notch. After that the sequence will be: - Lift the cage back into position and tack it in place (at roof level only.) - Make the forward bracing to turrets (while a-pillar's are still loose so I can flex them inboard to get a weld all the way around) - Notch and fit the door bars (while the b-pillars are still loose, again to let me flex them in for more access, although this will still be a pig to weld) - Fully weld up the foot plates for the A and B pillars. - Then the main hoop X bracing, the rear legs including their diagonal, and the dash and harness bars can all go in last. (As I can access all sides of them with the cage in situ.) I'll also be gusseting the main hoop and roof X in the centre, but thanks to the sunroof the roof one's accessible in situ, so I'll leave putting the extra heat in things until the cage is in it's final position and as braced up as possible. - Stand back and hope I'm happy with it!
Last Edit: Oct 26, 2017 9:52:14 GMT by RobinJI
bstardchild
Club RR Member Number: 71
Oct 26, 2017 19:54:30 GMT
Is the front screen still in the car and are you planning on replacing it?
Experience is what you get when you don't want it - I protected mine with 2 layers of card and duct tape and welding up the cage still caused it to be peppered with sparks!!
RobinJI
Yep, the screen's still in, and definitely knackered! It was far from great before I started, but after one too many times forgetting to protect it I've given up on it at this point. I guess it'll teach me to be more careful next time! As a small silver lining, when the time comes to replace it, I can fit a late 944 screen which will sit flush with the opening rather than inset like the 924one does, for a tiny little aero gain. I was hoping to keep going with it last night, but some bag of human excrement tried to break into the unit on Wednesday night. Thankfully they failed (quite miserably). So I spent a very long evening down there adding some serious reinforcement to the door along with a second lock and a shield over the main lock to hinder access to it. I'm happy it's a lot more secure now, but worried that if someone's got their eye on our stuff, they may come back better equipped next time.
Last Edit: Oct 27, 2017 8:46:19 GMT by RobinJI
Oct 27, 2017 12:03:45 GMT
they make fake motion activated rattle snakes for the intruders..... great work on the cage! JP
RobinJI
Oct 31, 2017 20:21:56 GMT
Thanks JP. I'm not sure if an intruder would be more scared or confused by a rattle snake in rural Somerset! Well I accidentally solved the 'will the screen be usable' debate: Woops! I was trying to knock the wiper spindle down through the scuttle and caught the edge of the screen. I can be a clumsy tit sometimes! Right, so cage progress: So with all the roof level tubes in place, it was time to cut the tack welds holding the cage up in place and let it drop down to hopefully give enough space to get the welder into the top of the tubes. Yep, that'll do! Welded up: Next up, bracing forwards to the front turrets: Then door bars and the dash bar: I didn't do the A-pillar bars yet as they'll make it a lot harder to get my head & arms into the foot-wells while I'm filling in all the holes I've had to cut in the shell, and their welds will be completely accessible even with everything in situ. Speaking of welds being accessible, some of them as expected have been a complete pain to get at, and as such haven't ended up with as neat weld as I'd like but I'm happy that everything's got a strong, full weld on it, even if it is a bit messy in places. I've also welded up the hole around the drivers side front leg of the cage, and made and welded in the spreader plates. I've left the cage leg poking right through the shell, end capped it and welded a spreader plate on the outside and inside. This way the leg's in double sheer and the spreader plates are sandwiching the box-section of the sill. Hopefully it should be pretty well tied into the cars structure! On the outside: And the inside: I won't be able to touch it for about a week not as I've got a few things going on, but when I'm back I'll continue with the passenger side foot, before filling back in the holes where the forward bracing passes through the bulkhead. Then I can get the A-pillar bars in and start putting the tubes in the back half.
Last Edit: Oct 31, 2017 20:29:43 GMT by RobinJI
WOW that is thorough work...welds look great. it looks very strong as well....
JP
proper job, i love the cage work.
RobinJI
Nov 21, 2017 21:33:20 GMT
Thanks guys! I've got this week off work in an attempt to use up my unused holiday before it resets over Christmas, so I've managed to get a bit further with the car, and hopefully I'll get further before the weeks out. With any luck I may even get the cage finished up! The front half of the cage is now done other than the gussets between the door bars. I've closed the holes through the bulkhead and tied both the front legs into the sills. I've also added some bracing at the b-pillars, as well as making up the passenger side 'turret' and adding the cages rear legs. Still to do are the main hoops cross, a diagonal between the rear legs, a harness bar and braces from the back of the top door bar straight back to the rear legs. Then tie the main hoop into the shell at the bottom. (I want to do this last to try and reduce the internal stresses in the shell) Hopefully there will be more updates later in the week.
Last Edit: Nov 21, 2017 21:41:03 GMT by RobinJI
RobinJI
Nov 22, 2017 23:40:16 GMT
Bracing back from the door bars to the rear legs. Hopefully, should the worst happen, these will provide a nice force path front to rear around the cabin. And the main hoop cross is in now too: I did a quick count earlier, and that's 29 tubes in place, with 2 left to go. Getting there!
RobinJI
Nov 24, 2017 21:14:58 GMT
31 down, 0 left I've also plated up the bottom of the main hoops legs and welded all the bits where the cage is touching the shell around the door openings. Rear leg with the huge hole I'd cut to get the hoop into place welded back up, then a 3mm spreader plate added. The plate had to be put on in two halves so I could get it around the cage. One side had to be L shaped so it went up the side just enough to reach the bottom of a recess, to let me get the welding torch in behind it. Me being fussy about getting the cage to be a really tight fit (and through the sills in double shear) has definitely caused some headaches! Then time for the underside. Again, the large hole I'd hacked out was filled back in then another 3mm spreader-plate added. I hole-sawed the plate to fit around the hoop, so it could be welded to it, then capped it off flush using the piece the hole saw had cut out: I'm going to leave that weld proud and visible, as it adds a clue to the method of construction, which could one day help a future owner or scrutineer out. The next job's to add the gussets to tie the two door bars together. (as well as some on the roof and hoop Xs) I've made templates already and I've got some 2mm plate waiting, so it should be a fairly quick job. This shot shows well how high the sills kick up at the back, which explains why the lower door bar doesn't bend down at the rear, and why I've wanted to pass the hoop right through the sills, and not end it on top of them:
Last Edit: Nov 24, 2017 21:19:19 GMT by RobinJI
Nov 24, 2017 21:16:14 GMT
just a complete triumph
RobinJI
Nov 24, 2017 21:34:27 GMT
Thanks Darren. I'm massively happy with how it's turned out. There's one or two welds that aren't quite as neat as I'd like, but they're all good and solid, and on the whole it's come out way better than I expected my first attempt at a cage to! It's been a good week in general, as I've also landed a new job out of the blue after being approached by an ex-colleague about a position at his new place. Not hugely relevant to this thread, except that it'll give me access to a TIG welder. My main job will still be CAD based, but I might be asked to help out with making the odd prototype or one off that doesn't fit in with normal production. I made it clear I was willing and eager to learn TIG!
Last Edit: Nov 25, 2017 9:33:07 GMT by RobinJI
