Mk3 escort project.
Zetec ecu fitted
Mondeo steels
Good Goodyear tyres
Good shell
Rs turbo injection tank
High pressure fuel pump mounted suitable for efi.
Zetec efi inlet manifold with injectors and throttle body , airpipe , airbox , air mass metre.
Ford puma gear linkage.
Ecu placed inside vehicle under carpet behind the glove box , wireing loom goes through firewall and comes out behind battery tray , all wrapped up tidy.
Xr3 exhaust
Doesn't come with engine or box but does include the inlet and efi parts listed above.
Boot spoiler which has been painted in past and is cracking of paint.
Fuel filler hole needs enlarging by a couple of mm so the rs turbo filler neck can fit in it , 5 minute job though.
Looks like a patch has been sprayed poorly around the petrol cap.
Could include a 1.3 hcs engine if wanted which is still attached to a 5 speed box.
Small square hole cut out of wing where aerial used to be as I was going to get a patch welded in there. About 2 by 2 inch.
Missing rear shoes and cylinder , washer jets and pipes , servo and master cylinder.
Small amount of rust on passenger front door.
Filler bodge has happened on drivers rear sill/arch , looks easy enough to remove and do properly .
Small amount of rust on arches but majority is solid.
Good starting point for a project , either source a zetec and drop it in , plug and play with the loom in there. As it was running before I removed the engine for my other escort.
Or fit a 1.3 that I can include to get it back to standard.
Overall it's a decent shell.
Photos to follow
Zetec ecu fitted
Mondeo steels
Good Goodyear tyres
Good shell
Xr3 exhaust
Photos to follow
