haydnw
Feb 14, 2018 12:48:08 GMT |
Thanks! Not sure why the head gaskets failed, but I guess it's most likely because the engine sat for years without proper coolant/antifreeze inside it. When I first removed the radiator and coolant pipes pretty much every waterway had evidence of rusty water inside it. So I guess the head gaskets were gradually corroded over time, though they didn't look all that bad when I took them off. The picture below shows what I found in the lower radiator hose when I first began dismantling things in 2016. Regarding the engine finally running, I am very happy, and very relieved! I'm surprised how smoothly it ran, to say it hasn't run for around 6 years (probably more) until recently, it seems to rev and idle smoother than many of the 24v cars I've seen videos of. Lots seem to have very lumpy idles, but not mine (touch wood). As for the first test drive, it may be a couple of weeks before I can drive it. I need to refill the brake fluid and bleed the brakes again, and bleed the clutch, after which it should drive in theory at least. However, the steering pump is noisy so I've bought a new one, and the steering rack is leaking fluid inside the rubber boots on both sides of the rack so the internal seals must have gone. So I'm gonna have to take that off and have it rebuilt. After all that, it should be driveable without leaking everywhere  The only issue is where can I drive it - there's not a private road next to my house or anything, so I either shuffle it up and down the driveway or risk taking it for a quick spin down the road and back...which isn't advisable when the car has no MOT, tax or insurance...
Last Edit: Feb 14, 2018 12:48:54 GMT by haydnw
1992 Maserati 222 4v (needs work) 1993 Alfa Romeo 75 3.0 Cloverleaf (needs lots of work) 1999 Alfa Romeo GTV 3.0 V6 24v (needs a bit of work) 1996 Alfa Romeo 164 3.0 V6 24v Cloverleaf (my third 164, this one is a keeper)
(Ex) 1998 Alfa Romeo 156 2.5 V6 24v (Ex) 1999 Alfa Romeo GTV 3.0 V6 24v (Ex) 1994 Alfa Romeo 164 Q4 3.5 'Savali' (Ex) 1991 Alfa Romeo 164 3.0 Cloverleaf (Ex) 1995 Alfa 145 1.6 Boxer Zender
haydnw
Since the last post I've done one or two jobs to maintain progress, the first of which was a clutch master cylinder rebuild. Having previously tried to bleed the clutch, only to find no fluid reaching the clutch slave, I removed the master to find it was pretty much jammed inside due to some light corrosion. I bought a rebuild kit, cleaned up the cylinder and its internals to the best of my abilities, and reassembled the cylinder. After refitting it to the car I was still experiencing difficulty getting it to bleed properly, but after adjusting the length of the rod on the master cylinder (where it connects to the clutch pedal) finally it began to bleed properly. With the clutch slave finally working sufficiently, I jacked the rear of the car up, fired it up and engaged first gear. With a bit of funny noise (more on that below) the gear engaged and the rear wheels began turning. So, I now have a 222 4V that will run and (should!) drive! I should probably make sure it stops properly too... There is another issue here though. There was a strange noise from the clutch when I selected first and upon investigating I found that there's a ring on the pressure plate that seems to have come loose. I have no idea how though?? I'm not even sure what its purpose is, though I assume it's there to 'even out' the force applied to the pressure plate fingers by the releaser. The question is, can it be fixed from underneath? I have good access at the moment due to the steering rack being removed from the car but it will still be very fiddly. I can get both hands into the inspection area on the underside of the bellhousing with relative ease. The picture is about as good as I could get, but there's a thin ring on one side of the pressure plate and a thicker ring on the other side. As mentioned above, the steering rack is currently removed because there was fluid leaking out from inside the worn rubber boots on each side of the rack. I had planned on having it rebuilt but the quotes I received were quite a lot more expensive than I anticipated. I wondered here if a 'Maserati Tax' was being applied... anyway, I contacted the ever-helpful David Askew (well-known Maserati spares supplier) who sent me an identical used rack the next day for a very reasonable price on an exchange basis. Thanks again David! All I need now is some new steering boots... which is proving to be a bit of a nightmare. I ordered some from Maseratispares.com last July and was told they didn't have any and would begin reproducing them, the first set should be ready in 2-3 weeks, and they would let me know (but they didn't). Since then, I've asked them for an update every couple of months or so, and they kept telling me 2-3 weeks. Fast forward to early February and I still haven't received them so I contacted them again and got no response, but I did receive an email from NL post to say I had a package from Arese Trade (same company) due to be dispatched to me. As of today (03/03/2018) the status of the package still hasn't changed - it hasn't been dispatched. I sent another email asking what the status was, and they haven't replied again. I should also mention that when I first placed the order along with some other spares, I heard nothing for two weeks until I asked what the status of my order was. Normally I'm very patient and willing to forgive delays and/or mistakes, but on this occasion, I think it's a bit of a joke. I'd like to know why they've been so lax to communicate with me since last July, what's so hard about emailing a paying customer to tell them the situation? Just be honest with me? I have no idea if I'll receive the steering boots or a refund at this stage. Anyways. I spent a bit more time working on the car's rust issues. I cleaned up the N/S floor, ground back the rust, cut out said rust, measured and cut some repair pieces and then spent some time shaping them as accurately as I could. I'm waiting for some better weather to weld them in though. Meanwhile I flatted (as much as I could be bothered ) the welds in the O/S floor, gave the floor a couple of coats of zinc primer, and then a few coats of paint. I also cut out one of the worse sections of the O/S outer sill so I could repair it and inspect the inner sill. I was pleased with what I found, considering the state of the outer sill: The last week or so has seen little progress unfortunately due to the 'Beast from the East' or whatever it's called (for those of you not living in the UK, it's the name of a rather cold period we're currently experiencing). It's been so cold that up here in Yorkshire I actually wore a coat on my walk to work... Haydn
07lilredwagon
@07lilredwagon
that sill is so clean inside!
very jealous over here!
JP
haydnw
Yeah it's really surprising to see it so clean, I expected some surface rust at the very least. But no! I had a more detailed look at the underside of the whole car the other day - it looks very good if I'm honest, though there is of course lots of surface rust on all the suspension components. One of the propshaft donuts looks a bit tired too. But, on the whole, it's pretty good from what I can see. However, I also keep spotting lots of little rust bubbles on the bodywork that will need attention in the near future before they get worse.
haydnw
I'm back, exactly 5 months (down to the date) since I last posted an update on here. Sorry and stuff. Basically my absence has been due to a number of things; laziness, selling the GTV and buying another V6 Alfa that then needed loads of work (some of which I knew about, but some I wasn't too pleased with), and an ongoing issue I've been having with my back that has got considerably worse since the start of the year. In fact I'm going for an MRI tomorrow evening to see what's going on. Said back problem has been a big issue in terms of work and working on the cars so not a great deal has happened compared to what could have been achieved this year, but I'm relatively OK at the moment so it's time to bring this thread up to speed. So yes, I sold the GTV and bought a 1998 156 2.5 V6 24v. I liked the GTV but had I kept it I just knew I would only end up throwing money at it to make it really nice, and I wasn't really in a position to do that given that I still had the Maser to finish, which was already progressing at a snail's pace. So I sold the GTV and put some of the money towards a 156 V6 that needed a cambelt job and various other bits and pieces to keep it going. A few days into ownership I found some godawful bodgery pretending to be front inner wing repairs (a common rust spot on these) so I ended up spending much more time on that than I intended. It drives really nicely though - full leather interior with electric this and that, a stainless exhaust and that lovely V6 engine. I keep umming and arring about selling it to fund some work on a 75 V6 Cloverleaf that I've inherited (pics below - it's been in the family for 20 years, and off the road under covers for the last 8 years) but after all the work I've done on the 156 I may as well hang onto it for a bit. It's currently out of MOT but should be ready for a test within the next week or so hopefully. So, the Maser. It's getting pretty close to being MOT-ready. Off the top of my head, the remaining jobs are as follows: -Small amount of welding on front N/S floor + flat, paint and underseal -Small weld on rear exhaust pipe -Small weld on rear O/S sill + flat, paint and underseal -Refit O/S skirt -Investigate one brake light and one reverse light not working -Fit new reverse switch (though since buying one the old one suddenly works intermittently) -A few bits of trim need fastening into place properly -Check all lights and whatnot -Refit exhaust heat shield That's it I think. Since the last update I've refitted the majority of the interior, replaced the steering rack and fluid, had the wheels refurbished with new tyres all round, done a bit more welding here and there, tried to fix an air leak on the throttle body, replaced the fuel filter, replaced a few bulbs, and so on. Progress hasn't stalled completely but the car could definitely have been MOT-ready months ago if not for the issues mentioned above. But it is what it is, and hopefully it'll be on the road before the end of the summer.
thebaron
Reboot Complete
Nice to see you are progressing with this. The refurb on the wheels looks great.
Clement
ambitious but rubbish
Ooooh the new additions to the fleet are quite sexy too!! Good work on the car, all those little jobs really do add up to a lot of time. Proper beast this, you'll scare small children and big children alike  I'm quoting myself from thebaron 's thread: If you want to get acquainted with what your engines sees and does you'll have plenty to learn with that device!
haydnw
Aug 11, 2018 16:26:52 GMT |
thebaron Thanks, it's good to get back to working on it. The wheel refurb is very good, not quite perfect but the price was also very fair for the work that was done so I'm chuffed with them. I just need to find some more screws for the centre caps, I only seem to have one of them... Clement I'll scare myself, never mind other people! I saw that diagnostic equipment posted on the Biturbo Facebook group. Impressive stuff, I wouldn't know where to start in making something like that. I gather the owner of said equipment was selling it but only under the agreement that it wouldn't be copied and thus replicated and sold to make a few quid. I can see where they're coming from but I imagine there would be a few buyers lined up if someone were to make some more. I spent a few hours outside with the car today; just doing odd jobs really. Painting and undersealing some areas, refitting some bits of trim, testing some of the electrics, etc. Nothing too exciting, and thus there's no pictures today! But it definitely feels like the car is getting really close to being back on the road.
haydnw
Aug 12, 2018 17:54:09 GMT |
Spent some more time out with the car today. Cleaned out the interior, applied some more paint and waxoyl to one or two areas and investigated a non-functional fuel gauge which turned out to be a bad earth on the side of the tank. Always nice to find an easy fix.
I investigated a couple of lights that had stopped working; turned out to be the usual case of bad contacts that just needed cleaning up a bit. The front right main beam had also stopped working which I discovered was due to the plug being disconnected from the back of the headlight unit. No idea how that happened, but I don't question these things any more...
I then jacked up the rear of the car, resting it on the rear lower arms such that the wheels were free to turn. Tested the brakes, handbrake and gears 1-5 + reverse; all working ok, including the reverse light switch which has previously been iffy.
A tricky bit of exhaust bodgery still leaks a little bit (much less than before though) so I'll stick a bit of exhaust paste on that for now. I'll aim to have the dodgy section replaced in the future so don't need a long-term fix. The throttle body leak seems to have gone which is good as it's another slight bodge. Despite cleaning it up and using a fresh rubber seal the damn thing still leaked, it's just a poor design really and I know they're prone to leaking but at least it's better now. The car seems to rev a bit more happily as a result.
What else to say... I'm typing this on my phone while sitting in the car enjoying a cup of tea on a mini-break (rude not to really, it'sa nice place to sit). I'll try to include a couple of pictures of the interior in its current state below. The pictures are slightly flattering if I'm honest as the interior isn't quite as good as it looks in the pictures.
haydnw
Aug 12, 2018 17:55:59 GMT |
haydnw
Aug 12, 2018 18:01:37 GMT |
Other things to mention: -coolant temperature warning light came on when the coolant hit 90 degrees C earlier. Not too sure what this signifies as it hasn't done this before, but I left it a bit longer and the fans didn't kick in either so I switched it off to avoid any overheating issues. -'Check engine'light usually comes on when it's running, sometimes goes away and sometimes stays. Again, it's not clear what's causing this as it seems happy enough?
On a separate note, I think it's time to arrange insurance... Getting ever closer to driving it for the first time.
Aug 12, 2018 21:11:13 GMT |
Great that you're getting there.
As for the coolant warning light at a guess I'd reckon the engine's normal operating temp is something like 86-88C, below 90C anyway, thus the warning light came on as the fan/s didn't kick in - solve the fan issue and warning light solved?
Keep the updates coming.
Last Edit: Aug 12, 2018 21:12:07 GMT by Woofwoof
haydnw
Aug 13, 2018 17:36:52 GMT |
I would assume that to be the case. I'm wondering if I need a new coolant temp sensor, it looks identical to those used on the V6 Alfas I've owned so shouldn't be too difficult to find. This issue has only just started, and only after I recently removed the CTS while trying to fix the leaking throttle body and then reinstalled it, having cleaned it up a bit. Coincidence? Probably not. I haven't touched anything else since the car was previously running fine (with working fans and no coolant warning light). Or it could just be an Italian quirk that'll go away on its own. I'm still trying to work out how much fuel is actually in it too. The gauge initially read about 3/8ths of a tank when I cleaned the earth and reconnected it, which I assumed meant it was now working ok. Since then it has dropped to just under 1/8th, and I've only had it running for around 10 minutes so there's no way it's used that much fuel, and there doesn't seem to be a leak anywhere. I've got another 20 litres to go in as of this morning anyway, which should equate to 1/4 of a tank, so once that's in I guess it'll be clear whether or not the gauge is playing games with me... I had hoped to have the car ready for an MOT today, all it needs is the fuel putting in and the O/S skirt refitting. Everything else seems to work ok (touch wood). Alas, my back is getting rather sore again so it'll have to wait for a bit. Weather has been plop today anyway
haydnw
Aug 22, 2018 10:55:46 GMT |
Well, I've just dropped the 222 off with the local garage for an MOT. I took it the long way round due to a) traffic and b) I wanted to check how well it was running/clean up the brakes and whatnot.
So, first impressions... It's not all good news. The steering feels very lazy and seems to take a moment to centre itself again once you've made a turn or gone round a bend. Not a big problem but something I'll have to look into. Tyre pressures and/or tracking would be the obvious culprits.
The coolant gauge still doesn't work properly. As I got to the garage it suddenly dropped to 0 degrees and the warning light was also on. I got out of the car to find coolant running out from underneath the front right wheel. I wasn't very happy about this, not only as it's a bit embarrassing having your car pee on the garage's forecourt, but also as it's an issue that really needs sorting before I can fully enjoy the car. As does the next issue...
The car isn't boosting properly. With gentle acceleration you begin to feel what this engine can do, but then it jerks and seems hesitant to rev at around 4k rpm. The engine doesn't cut out thankfully but this is another significant issue that needs sorting ASAP.
Other than that, no issues to report really. It sounds good, even if the cabin drone is a bit excessive. It seems to take a while to fire up too but that's not a big problem. I must admit though, that this morning's drive has knocked my confidence in the car a bit. Before today I felt pretty hopeful it would pass the MOT at the first attempt; now I'm not so sure...
haydnw
Aug 22, 2018 10:59:10 GMT |
thebaron
Reboot Complete
Aug 22, 2018 12:08:02 GMT |
1st attempt pass would be fantastic but very lucky for a BiT.
I jest partially but I think that it's a matter of patience as if you haven't touched something it's likely you'll need to at some point. They really seem to dislike periods of inactivity.
Fingers crossed for the pass all the same.
haydnw
Aug 22, 2018 12:12:07 GMT |
I agree 100%. It's not too surprising that the car is a little unhappy given it hasn't been on the road since 2012 but it's a bit disappointing nonetheless.
All I can do is wait for the result, and take things forward from there.
Aug 22, 2018 12:35:20 GMT |
Again, it's probably easy to guess from my username how intensely jealous I am of your car. I've always wanted one. And a 75, so double jealous.
For the weird boost-cut thing check for boost leaks. My dad's 430 had similar symptoms when one of the two pipes coming off the intercoolers popped off. It was still getting enough boost through the other one under light load/low rpm to drive at least semi-normally, but as soon as you tried to go a little faster it would feel a bit like an ignition cut/hesitation.
Could be a simple fix at least (although 'simple' is a relative term given how much engine and pipework Maserati crammed into that engine bay).
haydnw
Aug 22, 2018 17:01:30 GMT |
Hi biturbo228, thanks for the kind words. I wouldn't be too jealous though, it's giving me a few headaches at the moment! The 75 was awesome to be driven to school in, what a noise from that V6, and my mother (who drove it at the time) didn't hang about...
Couldn't agree more re: the pipework, it's really packed in there. Thanks for the tips too. I think the problem might be intermittent, as on the way home I gave it full throttle in first gear (assuming it wouldn't boost) and suddenly ot absolutely flew forwards! That put a big smile on my face...
...which was needed, as the car unfortunately failed the test. I'll post a pic of the failures below, ignore the winsdcreen washer one though as they're working fine so not sure why they're listed? Essentially it's gonna be a weekend of fettling the brakes, replacing a couple of sensors and attempting to make some adjustments to how it runs. The failure list could be much worse to be honest, so in some ways I'm quite pleased. But the coolant/fans issue remains a significant concern.
haydnw
Aug 22, 2018 17:01:49 GMT |
