andyborris
Jan 19, 2017 12:17:49 GMT
2 M52 vic fans, both believed to be good, £10 each or £15 the pair.
E36 ZF 5HP18 autobox with convertor, ring gear and cooler pipes, the cooler was missing a lot of the fins, so may have been binned! £75 collected.
M52 starter, good condition £15.
M52 DMF with clutch plate and release bearing, seems to be within tolerances, £15.
I will post the everything except the gearbox and the DMF will cost a fortune to post! Pictures available.
Offers accepted, especially if you collect, I'm near Margate in Kent.
Any chance of size and weight for the flywheel so I could price a courier?
A better question would also be is it the 228mm or 242mm clutch?
andyborris
Jan 22, 2017 12:07:09 GMT
13kg and clutch plate measured 240 (ish), so I guess it's the 242mm type?!
BMW E36 PartsChasR
@chasr
Club Retro Rides Member 170
Jan 22, 2017 18:18:26 GMT
2 M52 vic fans, both believed to be good, £10 each or £15 the pair. E36 ZF 5HP18 autobox with convertor, ring gear and cooler pipes, the cooler was missing a lot of the fins, so may have been binned! £75 collected. M52 starter, good condition £15. M52 DMF with clutch plate and release bearing, seems to be within tolerances, £15. I will post the everything except the gearbox and the DMF will cost a fortune to post! Pictures available. Offers accepted, especially if you collect, I'm near Margate in Kent. Do you know if the fan combos will fit an E46 328i with the M52TU engine? It's not for me but a mate with cooling issues.
Jan 22, 2017 21:34:11 GMT
If I can get a reasonable price for a courier then starter and flywheel please.
andyborris
ChasR, RealOEM gives the same part number for E36 and E46 m52 for both the fan and the coupling, so I think they should be OK.
I've no way of testing them, other than turning by hand, light pressure doesn't turn the blades relative to the coupling, but hard pressure does. I'm pretty sure that this means they work, slow speed airflow lets the engine spin the fan, high speed airflow and the fan "freewheels"?
daslandroverman, where in our nation are you?
I'm on the Cumbrian coast, not far from the controversial nuclear hotspot of Sellafield.
Nice part of the world really...
andyborris
I'm on the Cumbrian coast, not far from the controversial nuclear hotspot of Sellafield. Nice part of the world really... Got a friend visiting soon, but he lives on the Yorkshire side of the country, thought I might be able to relay them! And hot weather is nice........ will get back with a post cost.
Had a look myself, less than £10 seems doable.
andyborris
Who was that with? And are you OK with that price?
Jan 23, 2017 16:43:23 GMT
Parcelmonkey. Seems pretty good really.
