johnd
So you guys once gave me some help with a door handle swap and grill design on my kadett c Its slowly coming along (second side be in primer tomorrow) It usually has bumpers and I'm not set on the wheels - they can wait Anyway you can see where the old fuel flap was, i was going to make a smooth liftable cover but I'm not feeling it Show me cool caps that could be adapted to go there Anything..... even if they protrude
Last Edit: Jan 14, 2017 13:05:13 GMT by johnd
Bookmarked I'm thinking about something similar for my motor and have been looking around for inspiration. Some food for thought ... the cap on a BMW E36 is opened by cable from inside the cabin, and locks when you remove the ignition key Maybe get the mechanism from a breaker and modify to suit yours? And some cool stuff - just because. OK ? 50s Chevvy 55/56 range GMC Others
Love what you've done with the grille!
The fuel cap is tricky, anything you do that keeps the original trapezoidal hole (except another trapezoidal flap) will look odd and unfinished. Something like the Newton ones (and I really DON'T like the "ring pull" ones!) would need flush fitting on a smoothed body. For my taste, I would smooth it over it entirely and make the filler inside the boot.
Steve
johnd
Thanks, i was thinking of losing the hole and fitting an audi tt one... easily available
This is AWESOME! but it looks like a right so-and-so to use! Steve
Personally i'd put it inside the boot, at the back. But if you don't want to go that route, how about on the rear panel like a '66 Mustang. or put it behind the rear numberplate like on a 77 Firebird.
79cord
Cannot recommend where to get them but popular with rodders & motorcycles pop-up filler cap Or continuing your oval hole theme a standard screw-in one with recesses each side (making oval) to grasp it.
Last Edit: Jan 4, 2017 23:27:14 GMT by 79cord
johnd
Thats very nice too
The boot wont work, needs to stay where it is as i want to retain the standard tank
johnd
Not wanting a flap, mocked one up and looked poo
Curtis
New Mini? Zoom, in keeping with the MX5 Door Handles? Datsun 521? Jeep Wrangler? Defender? Racing port, for comic effect?
Driving: Shitbox Honda S-MX
johnd
Bought a tt one
Curtis
Be interested to see how you make the curve of the TT panel work with the flat panel on the Kadett
johnd
I probably will only use about 10mm around the recess
johnd
Handles went ok so this will hopefully be similar
VIP
I probably will only use about 10mm around the recess But the entire cap is curved in one direction?
johnd
Its a very slight curve tbh The car has a slight curve too
BT
I was going to suggest a TT flap but didn't think it would be your bag. I like it.
Think thats going to be pretty smart.
1973 MK1 2600 Capri - Located in Texas 1976 3.0S Capri - X-Pack long term Project 1978 2.0S Capri 1984 Transit County MK2 4x4 LWB 2.5DI 1985 2.8i Special Capri (v8 5.0L) 1986 2.8i Special Capri 1987 280 Turbo Technics Capri 1993 1.8TD P100 - Beater, parts collector 2008 BMW 320i Touring - Daily
My mate does these, predominantly for motorcycles, but would also look the 'nads' on a motor Company is called race fit
