Right I've taken it for it's mot and it's failed. The work is about £350- £400 worth (estimated) so bearing this in mind I'll sell it for 800 which is £500 less than i was asking. This is a firm price. I'll put the list up of failures because i don't want anyone to think I'm hiding anything. Its mostly lights, needs a few bulbs changing to coloured and headlights adjusting. Plus the exhaust leak, (it's a small 5p size hole in the section between the cat and middle silencer.
Then the bigger issues are the front subframe needs changing or welding, (online the part is £105)
The seatbelt anchoring point needs welding and the subframe anchorage needs welding too. Typical vw wheel bearings (super cheap to fix)
Here's the original advert
So the good points
Omp coilovers all round
Big bumper conversion
New exhaust
Mimm 1800 wheels with toyo proxes
New alternator
New brake pads
Loads and loads of history. All receipts back to original purchase.
Mot til January 16th. It passed the last 4 with no advisories
Interior is original and superbly clean. No sagging headlining or cracked dash.
140k
This car has been super reliable and i really do enjoy it but unfortunately two big dogs don't fit inside it. Like i said I'm not sure i even want to get rid.
Bad points
Dent in the passenger side door
Front drivers side wing has rust on it so could do with replacing but its just the bolt on part of the wing so easy enough to change and pretty cheap.
There's a super annoying thing with the exhaust. All it is is a missing rubber exhaust mount missing from when they fitted the back box. It makes a racket and is a super easy thing... But it's cold outside so I've become lazy.
Send me a text or give me a ring
Realistically viewings will probably have to wait til new year
07983587956
So the good points
New exhaust
New alternator
New brake pads
140k
Bad points
07983587956
