sleag40
I've no longer space for any more!
Nov 14, 2018 19:04:34 GMT
Surprised klokkerholm don't do you a wheel tub 😕 they do for mk2 astra as I bought some. Wire wheel of truth has been quite honest, eek Can't find an inner arch panel anywhere chief, I'm probably gonna have to get creative! use an outer repair panel to make up an inner one thats what ive done I'll most likely get away with doing that on the nearside - there's a bit more inner arch left on that side. I want to make as tidy job of it as I can, and I'd like to avoid a patchwork repair if at all possible - if there's no other way round it, bits and pieces it will be. Maybe a Mk 3 Cav wheel tub could be adapted to fit. They might be just as hard to find though 😟 A member of mk2cav.com used a MK3 tub to repair his car, but it took a lot of persuasion + patching up. The MK3 inner arch is a different shape, and the fuel filler hole is in a different place. No disrespect to the guy from me, but I'm gonna try to find a more elegant solution if I can.
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
sleag40
Nov 14, 2018 20:43:30 GMT
A bit more excavation this evening - the dubious repairs to this side were a fair bit easier to remove due to being attached with pop rivets instead of welding. There's a lot more inner arch left on this side, but the rearward end visible in the next pic is another pop riveted repair yet to be ousted. Because the wheel arch came away so easily, I had enough time left to have a pop at the rear valance. Should be an easy enough job to repair this - I have an outer panel, just need to replace the bottom inch or two of the inner part. Bonus shot of some of the junk that has parted company with the car recently.
ivangt6
Club RR Member Number: 132
1988 Mk2 Cavalier 1.8GLiivangt6
@ivangt6
Club Retro Rides Member 132
Nov 14, 2018 22:54:49 GMT
I never cease to be amazed at the lengths some people go to to bodge a car. I wonder what else in life they have such low standards for. Anyway top work as always. Will be nice to see the end of the rust and some new metal work being let in
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
as i said before use outer repair panels too line up and bridge inbetween
pabblo
Nov 15, 2018 12:59:31 GMT
Hi, was just reading about your conundrum regarding an drivers side inner rear arch panel. Spotted one for the mk1 Astra / Opel Kadett, it is from Klokkerholm as well. Not sure on dimensions or the exact profile, but as they are from a similar era it might work with a Cavalier mk2? www.carz2.co.uk/vauxhallopel-kadett-d--vauxhall-astra-80-84--mudguard-inner-wing-98134-p.aspAnnoyingly I couldn't find a passenger side, but maybe I wasn't looking in the right place. One out of two isn't bad though, good luck with the welding. I need to do the passenger wheel arch on my Fiat Uno, I've got the panels but can't weld. Wouldn't even know where to start, so fair do's for getting stuck in!! Liking your Cavalier, my dads builder friend had a white GLi hatch for years. Was a brilliant car, I remember a school friend convinced his dad to buy an mk2 LXi saloon as well back in the late 90's. My bother liked it so much, that's why he owns a Mk3 Cavalier now! Anyway bookmarked the thread
Nov 16, 2018 23:01:09 GMT
Last Edit: Nov 16, 2018 23:04:53 GMT by Archie01
sleag40
Nov 18, 2018 15:28:59 GMT
Many thanks for the links sir! I already have repair panels for the lower rear corners - I'm hoping I won't need to replace the whole quarter panels, but it's good to know that there are several options for sourcing them. Collected a decent pair of genuine wings this morning. They were a long way away, but the pair were less than half the price of one new GM wing. No more actual work done yet, but less bran flakes to contend with can only be a good thing!
Last Edit: Nov 18, 2018 15:29:52 GMT by sleag40
sleag40
Nov 24, 2018 21:30:31 GMT
Armed with a couple of hours spare today, I prepared myself for the deep joy of dashboard removal. I don't have a steering wheel puller, so hit it with the violent wiggling trick. After a few minutes of that, coupled with a bit of professional grade language, it popped off. As is normal, the Haynes book gave me a few clues, but I had to work out how to remove some of the parts which ate up a fair bit of the time available. Once I'd discovered how to remove the passenger side air vent, radio and central vents, the operation sped up somewhat. And its out! Took out the comedy air vent ducting (similar to the MK1) I'd run out of time now, so had to leave the heater box and wiring spaghetti for another day. My target for the day was to get the dashboard out though, so jobs a good 'un!
Nov 24, 2018 21:51:46 GMT
Good work chap, but you left the bit of the story out, where you realised you could leave the wheel on 😋
sleag40
Nov 25, 2018 19:18:15 GMT
All interior pieces (and lights too) have been stashed away in my dining room today. This should ensure they stay clean, and don't get any moisture damage. As I have no idea how long it'll be before it all goes back together, all upholstery has been stored without anything resting on it to avoid distortion. As you can imagine, living alone is advantageous in situations like this! I'll be cracking back on with the scooter for a bit next, so may not have much to update on this until I get back on it in the Spring.
Nov 25, 2018 21:19:33 GMT
if you take the ps front wing it should match profile of of ds rear inner arch cut to size sameon the other side
Nov 25, 2018 22:29:52 GMT
Looks like my spare bedroom, 5 years, five! So far!
tofufi
South West
Looking forward to seeing this get some love. The quality of the past repairs is shocking!
sleag40
Looking forward to seeing this get some love. The quality of the past repairs is shocking! They certainly were! Grabbed an unexpected bit of stripping time on this earlier - the bumper brackets, side repeaters, mirrors, wiper arms, windscreen trim, door membranes + removable parts of the grill all came off. Window bottom trims were next - great care was taken to avoid distorting these as they're made from a soft alloy - I seem to have gotten away with keeping them nice and straight. More progress to follow sporadically!
1988 Mk2 Cavalier 1.8GLiMercdan68
@forddan68
Club Retro Rides Member 68
Nice to see this being restored These just seemed to disappear overnight Great work fella
sleag40
Dec 16, 2018 20:11:29 GMT
Nice to see this being restored These just seemed to disappear overnight Great work fella Many thanks Dan! Another bit of unexpected time spent on this today. I decided to do a bit of bran flakes banishment - and thought I'd ease myself in to it by tackling something non structural + hidden from view when completed. (Just so I could experiment a little!) First pox patch pruned Making a replacement piece Welded in (a bit of hole chasing occurred, no doubt due to the poor condition of the metal I was welding to in some areas) The other side was done in a similar style Once the replacement piece was shaped, I decided to postpone the welding until I've grabbed my 0.6mm wire from home. I'm thinking the lower power required to melt it may make it less likely to blow holes in the poorer patches of metal. I'll find out how well that goes next time!
sleag40
Day off today - so pencilled in a couple of hours on this heap. First up, the bonnet came off in preparation for removing the engine/gearbox at the weekend. (time on two post ramp permitting) [ Next I decided to remove the outer part of the front valance. I was going to replace it in its entirety, but it would be difficult to weld it on without unsightly beads on the end of the chassis rails. This way I had the joy of unpicking all the spot welds holding the front part to the beam behind it. (And look forward to separating the two parts of the GM replacement!) Before leaving, I ran it up until the fan had kicked in a couple of times. I was totally impressed that it started immediately after a couple of months festering!
sleag40
@forddan68
Nice update, good to see the scuttle And screen surround is rock solid
Last Edit: Feb 9, 2019 18:35:36 GMT by Mercdan68
Thanks for the updates, i wondered where this had got to. Keep up the good progress.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
