Dec 12, 2016 22:51:51 GMT
As above my car useless BIL needs the rear flexi hoses changing on his 98 525, just the caliper up ones not over axle. Are there any foibles i need to know or is it spanners, fluid and a pressure bleeder easy?
Dec 12, 2016 23:22:07 GMT
none at all that I recall, slider pins are 7mm hex iirc, they have drum handbrake so no faffing there.
Brake/flare spanners, fluid & pressure bleeder easy IMO if they are still the originals.
Dec 13, 2016 18:01:13 GMT
Cheers chaps I was hoping that was the case.
Only thing to watch for is rotten steel solid lines that shear off when you try undoing the union as they'll probably be a bit crusty if they haven' been changed.
