Dec 10, 2016 21:20:35 GMT
Hey guys, bought these for my MK1 Caddy but sold it on now so no need for these. They are 13x7 et20 4x100. Tyres are 165/55. 2 have a good amount of tread on. 2 have camber wear. They are the same spec (ie size and offset, not pcd) as i have on my mk2 fiesta, so these pics are to give you an idea what they look like fitted to something Would suit Polo, Nova,Golf etc etc Looking for £400 collected from Felixstowe, Suffolk. Can post for £40 cheers
Don't Fool with the OLD Skool
Dec 11, 2016 11:01:53 GMT
What brakes will these clear? Assume CB is bigger than 57.1mm? cheers
Dec 11, 2016 17:44:06 GMT
Yeah centre bore is big on these (69mm iirc)
Not sure what brakes they clear. I can get them over XR2 front calipers, but only just.
Dec 11, 2016 18:29:40 GMT
Is that 240mm brake disks on the xr2? Looking to clear 256mm but it does depend on caliper shape and wheel offset, need 310mm or more internal diameter at the hub mounting face (if i remember right, might have been 320mm).
Dec 11, 2016 20:21:21 GMT
I'll have a measure for you tomorrow if you like bud, see if you can work out if they will suffice or not.
And yeah standard XR2 discs are 240mm
Sorry to be the bearer of bad news but they won't fit over 256mm.
Dec 12, 2016 11:18:01 GMT
Just been out and had a measure. I make it 266mm at the narrowest point, so as far as I can see 256mm discs should just about make it? Or is there more to it than that? Here is a poor quality picture.
Dec 12, 2016 12:14:57 GMT
OK thanks for your efforts, not many 13 wheels will clear the 256mm brakes but worth a shot asking, internal diameter has to clear the caliper as well mind so has to be quite a bit more than 256mm
Dec 12, 2016 14:26:23 GMT
Ahh yeah, makes sense! Good luck with your hunt!
