Winter driving tipsDarrenW
@darrenw
Club Retro Rides Member 74
Nov 19, 2004 10:29:19 GMT
Thought this might be a good idea for a thread? Some hints and tips for keeping your retro-ride running through the winter. I'll start: A thin layer of vaseline smeared on door seals stops them freezing to the car and getting wrecked as you try to pull the door open
Nov 19, 2004 10:34:15 GMT
repeat after me, Higher gear, lower revs, your mission is to shout this at anyone wheelspinning their way up a hill in the snow,..
racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Nov 19, 2004 10:50:00 GMT
or lower gear higher revs if they are struggling to get it sideways in a carpark!!
Nov 19, 2004 11:13:48 GMT
Don't sod about with de-icer, simply put a convector heater in your car for 10 or so minutes before leaving.... Kill 2 birds with the 1 stone... warm car and clear windows ;D
Nathan
Club RR Member Number: 1
Winter driving tipsNathan
@bgtmidget7476
Club Retro Rides Member 1
Nov 19, 2004 11:32:43 GMT
Find Nice open Car park, And play
SkoCan
Quando omni flunkus, mortati
Nov 19, 2004 11:38:44 GMT
Block heater anyone? Or do you guys need them?
Good snow brush and ice scraper Lock de-icer Nice mug of hot chocolate ;D
Winter driving tipsBenzBoy
@benzboy
Nov 19, 2004 12:02:47 GMT
Block heater anyone? Or do you guys need them? Fortunately it never really gets that cold here - although with the crazy weather we have these days, who knows? A good blast of WaxOyl under the car should stop all that nasty salt doing damage. And one thing not to do - using hot water to de-ice the windscreen. It can smash it . Bit of a no-brainer that one, but I've seen it happen!
Nov 19, 2004 12:06:14 GMT
Use luke warm water out of the tap - not hot water Done it for years with no probs - unless I`m in the Focus with its heated front screen
Nov 19, 2004 12:44:10 GMT
even cold water from the tap will do it if you arn't driving far otherwise it will freeze again. but i always try water before deicer because that does the seals and blades up and put a sheet over the window. yeah always use a high gear NO throttle round corners in RWD and same with brakes, you will just lose it
Assumption is the mother of all f**k ups
Nov 19, 2004 13:04:46 GMT
WEAR AN EXTRA PAIR OF DUDS
Nov 19, 2004 13:32:35 GMT
Great tip with the vaseline. I could have done with that this morning! Frosts do a dashtop ceramic 12V heater. That might be handy to warm the inside up. Someone does a mains water heater that warms up the engine for you!
Peugeot 307sw - Suzuki SV650S - MX5.
@benzboy
Nov 19, 2004 14:52:37 GMT
What's peoples opinions on warming the engine up (i.e.: leaving it idling on the driveway). I've never done it myself as a) it's a bloody waste of petrol, and b) the engine may be warm but the transmission will still be cold, and this can cause damage. There was an old statement from Mercedes notifying owners of this years ago. They recommended that the car is driven soon after starting, but keep the revs low. That way everything warms up at the same time.
HytestA
Cant beat a good bit of rubbing :D
Nov 19, 2004 15:22:24 GMT
don't buy an aircooled VW to drive in winter ! :/ I think i may have to get one of them convection heater thingamejigs, I remember having to scrape the ice of the inside on my last van
A decent wooly hat and a pair of gloves is my tip
racer86
Nov 19, 2004 15:55:17 GMT
you shouldnt leave your car running to warm up, as soon as you start it you should drive it. when could at idle the oil is thicker and with the low engine speed will not form a film around the bearings and cam causing metal on metal contact which is bad, very bad. the best thing to do is warm it up at 2000 to 2500 rpm and when driving it don't bog it down in say 5th but don't rev it more than 3500rpm or so.
Nov 19, 2004 19:13:32 GMT
Fortunately it never really gets that cold here Easy for you to say, you're in England, it is that cold here, the warmest it was in Greenock today was about -2 degrees at noon when the sun was shining. It was no doubt a good bit colder in the morning. And with the wind today it felt worse. Still no snow oddly enough, it was dry as a bone. It's snowing up north though. One bit of advice for successful driving in winter... BUY A REAR ENGINED CAR! ;D ;D ;D ;D (and use tonnes and tonnes of antifreeze!! ) Also remember if you have a starter handle for your classic, even if it rarely needs it, then keep it handy, it might refuse to start.
"He's not the messiah, he's a very naughty boy!"
Nov 19, 2004 19:20:29 GMT
AFTER BUYING REAR ENGINED CAR, BUY BIG BAG OF COAL TO PUT IN FRONT TO PREVENT MAJOR UNDERSTEER ON ICY ROADS ;D ;D
Nov 19, 2004 19:25:17 GMT
I have tonnes of spares and miscellaneous curse word in the front of the Imp, so it's alright though! ;D ;D ;D
Nov 19, 2004 19:26:54 GMT
yer all a bunch of wimps ;D i used the motorbike today its not that cold trust me but them it needs to be snowing b4 i use tha car
2001 HONDA CT110 (NOT RCV)
Nov 19, 2004 19:29:05 GMT
yer all a bunch of wimps ;D i used the motorbike today its not that cold trust me but them it needs to be snowing b4 i use tha car Have you ever felt an Imp's heater? I wasn't warm either! ;D ;D ;D ;D
Nov 19, 2004 19:56:38 GMT
I got the 850's heater working during the summer and then discovered I couldn't turn it off
