Nov 22, 2016 19:00:04 GMT
Anyone got or used one. Looking for a engine hoist to use while swapping engines in my fiestas.
Don't want to spend hundreds but there are several for about £100 on eBay. Are they any good?
Nov 22, 2016 19:16:33 GMT
the main issue is you always need to use it at fell stretch, if fishing an engine out of your average front wheel drive retro. and this where the hoist is rated its least (due to laws of leverage) and this is reflected in the prices
bl1300
Nov 22, 2016 20:48:52 GMT
Got a two tonne Draper one myself. I think it was about £250 of ebay. Works fine for me and i've been lifting Land Rover TDI lumps with it and they aren't that light. Max jib length is only rated to 500kg though. Normally use mine at the 1000kg slot
Current fleet.
Nov 22, 2016 21:40:24 GMT
I bought a hawk tools version, the black one for a hundred delivered, considering it weighed about 75 kilogram it can't have been cheap to courier. Used it to change a caddy engine and it's been fine seems decent enough. Only thing that can go wrong with it is the ram and there cheapish and easy to change. Thought I might as well buy one as to rent one locally was £50 a pop. Most of those on eBay look the same, maybe different colour or brand, but I bet they are all made in same factory in China.
Nov 22, 2016 21:51:24 GMT
using it at full reach for most people isn't an issue, I doubt many cars have an engine and box combination that'll trouble the rated weights if the crane will actually reach.
ian65
Nov 22, 2016 21:57:39 GMT
Thanks for the input guys, I am well aware of the rating of hoists at different reaches as I am an engineer at a mechanical handling company, but thanks for making sure I don't slip up. I can't imagine many engines and boxes are close to 500kg or even the 250 of the smaller hoists.
I am more interested in the quality, but like people have said. i'm sure they are all built in the same factory (the cheap ones anyway) so should be pretty similar.
Although I have been kindly offered one to borrow for a period of time from a local member which is very kind of them.
Cheers Matt
bl1300
That looks identical to my Draper branded one which as I said earlier is fantastic.
Current fleet.
alecf
Nov 23, 2016 11:58:43 GMT
got the same was as pictures above, again not draper or automec 9although I have one of there 2 post lifts which is great), so probably all made as mentioned before in the same factory. Never had an issue with rover v8's down to mini engines. its a great bit of kit and comes in handy for other stuff too.
bl1300
Nov 23, 2016 17:27:18 GMT
What iI really want is a hoist that works on rougher surfaces. I quite often find myself having to hoist on compacted shale farmyards the little castors dig in and make the hoist a pig to move. I wonder if any are made with bigger wheels or a wide roller on the back which is less likely to dig in
Current fleet.
Nov 23, 2016 19:07:09 GMT
I can't imagine many engines and boxes are close to 500kg or even the 250 of the smaller hoists land rover 2.25 engine is 200 kilos on its own... (4 cylinder iron head pushrod engine of typical 60s layout) thats the reason i paid a bit extra for a 2 tonne, plus i think the jib was a bit longer, which is useful for rear drive which tend to be at the back of the bay
Last Edit: Nov 23, 2016 19:10:58 GMT by darrenh
andyborris
Nov 23, 2016 19:19:30 GMT
I too have one that looks the same as above, had it for about 10 years now, it'll lift the front of the Triumph complete with drivetrain on full extension and still works fine.
As above, only fault is it's hard to move on a less than smooth floor.
Nov 23, 2016 19:43:40 GMT
What iI really want is a hoist that works on rougher surfaces. I quite often find myself having to hoist on compacted shale farmyards the little castors dig in and make the hoist a pig to move. I wonder if any are made with bigger wheels or a wide roller on the back which is less likely to dig in Hi, The problem with having bigger wheels is they won't go under the car, probably easier to put a sheet of ply down. Colin
Nov 23, 2016 20:27:10 GMT
i bought a sealey one 15yr ago, still going strong. you get what you pay for.
Nov 23, 2016 22:23:48 GMT
I have a large, heavy duty engine hoist for sale. It's non-collapsible, and has been used for moving large v8 engines about. I'm losing my storage, so I will let it go for 100 quid. Must be collected from West Sussex though...
OUTRUN
13...
For the money, you can't knock a Clarke. ![](http://i974.photobucket.com/albums/ae221/l14mnp/MR2%20Turbo/20160809_160113_zpsig3my8we.jpg)
I need your help to get back to the year 1985.
I have a large, heavy duty engine hoist for sale. It's non-collapsible, and has been used for moving large v8 engines about. I'm losing my storage, so I will let it go for 100 quid. Must be collected from West Sussex though... Thanks for the offer but not for me I'm afraid as I have limited space.
Nov 24, 2016 20:10:51 GMT
For the money, you can't knock a Clarke. ![](http://i974.photobucket.com/albums/ae221/l14mnp/MR2%20Turbo/20160809_160113_zpsig3my8we.jpg) I've got one of these it's technically my brothers but we share it and it's done so much work over the years and then you just fold it up and stick it in the corner id highly recommend it
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
hitman
Nov 24, 2016 21:30:50 GMT
agree with overrun and discostew,they are spot on,ive got the non-collapsible one aswell (bought before the clarke) for the real heavy lifting but they take up a lot ov space
Clarke all the way I had a draper before but the legs sit higher and not as easy to get under some cars, Clarke iv never had an issue
