Nov 20, 2016 11:50:50 GMT
I have a small facet pump (box type) I want to mount it near to my tank but as the tank is under the car I wasn't sure what's the best way?
Any advice would be ideal as the bracket I had thought of would be quite tall on one end as the floor slopes away for the rear axle.
79cord
Nov 20, 2016 13:07:54 GMT
My car mounted its pump low beside the tank, rubber mounted on a bracket under a frame rail, along with filter. Another actually added a full metal shell around it for sound deadening!
Nov 20, 2016 14:59:43 GMT
Mini exhaust mounting bobbins will help with noise isolation. Either fasten the pump to a plate, use the bobbins to mount to floor, or use the bobbins directly on the pump.
Either way, remember you're going to need a earth strap for the pump if you mount it like this.
Last Edit: Nov 20, 2016 15:00:06 GMT by jifflemon
slater
Club RR Member Number: 78
Facet pump mounting slater
@slater
Club Retro Rides Member 78
Nov 20, 2016 15:43:37 GMT
Try and keep it low and with a short run to the tank to help it prime. Ive had trouble using them on standard tanks where they have to prime themselves.
