Nov 16, 2016 21:36:22 GMT
Any VW T4 Gurus on here ? As you have probably seen on my other post regarding the problem i have with the current engine Just thinking outside of the box for a moment but has anybody done the 2.4 to 2.5 conversion, i belive the Volvo V70 uses the VW 2.5 TD engine although the sump / manifolds / mountings will need swapping over, these seem to be cheaper to buy either as a loose engine or a complete scrap car which is probably the better option as you get everything with it also can hear it running Any input and advise welcome Thanks Dave
Nov 16, 2016 21:43:17 GMT
they use a VP37 electronically controlled mechanical pump, so using a T4 donor would be a lot easier with regards to wiring looms.
Nov 16, 2016 21:55:29 GMT
Thats what i was thinking could be another issue so if got a complete car could use the matching Volvo ECU`s Or maybe another option is to use the T4 mechanical pump and injectors on the 2.5 , cant see any information on the T4 T5 forum at the moment Thanks Dave
Nov 16, 2016 22:52:52 GMT
non turbo pump wont have the boost compensation that the ECU has, or a mechanical turbo pump.
injectors aren't electronic on the 2.5, bar having the needle lift sensor on one of them.
Nov 16, 2016 23:09:31 GMT
Nov 17, 2016 16:41:02 GMT
Got an lt35 turbo 5 cyclinder sat on the drive, there's another doner for you.
Engines mint but the Ecu is shagged I think., pretty sure it only controls the fbw throttle.
Currently bodged it to run mechanically. And with a throttle cable
Nov 20, 2016 19:14:05 GMT
I've not pulled an electronic pump apart.......how easy was it to bodge up to be cable operated?
hario
S202 C300STD
Nov 21, 2016 19:31:04 GMT
I've not pulled an electronic pump apart.......how easy was it to bodge up to be cable operated? Not possible, the mechanical pump has a whirry-spinny weighted governor with springs and that
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
