EDIT* more money off, and I'm going to service the brakes with a clean and new pads on the front and some fresh fluid etc. READ THE LAST POST ABOUT THE BRAKES.
First things first, I wanted to own and drive this but can't really justify/afford to run another vehicle, so I'm selling it on behalf of my folks who have a new old folk friendly-mobile.
I'll start with a link to the thread with what what little I know about it here you go
A quick rundown here then, about 70,000 kms on the clock, always garaged, everything repaired as needed by MOT, new stainless exhaust three years ago, bodywork isn't perfect but it's an honest old boat, and completely stock. Interior fabric is sunfaded, dasboard is cracked, there appears to be a stain in the boot (I'm assuming from my Mums shopping rather than some mafia hit scenario, although it's plenty big enough for that), new battery.
You're more than welcome and positively encouraged to come have a look and a drive. That gives y'all some pondering time on this rare old beast, very very few of these about in this country, just ask oldguy
According to wiki-lies it's a 6th gen X80, here's the specs,
Powertrain
Engine 2.4 L 22R I4
Transmission 4-speed A340 automatic
Dimensions
Wheelbase 2,682 mm (105.6 in)
Length 4,690 mm (184.6 in)
Width 1,695 mm (66.7 in)
Height 1,375 mm (54.1 in)
Curb weight 1,480 kg (3,263 lb)
here's some mot history:
Registration number: H717HRL
Vehicle make TOYOTA Vehicle model CRESSIDA Date first used 31 December 1991 Fuel type Petrol Colour Grey
MOT history of this vehicle
Test date 18 May 2016 Expiry date 26 May 2017 Test Result Pass Odometer reading 113,408 kms MOT test number 9443 8917 3325
Test date 1 May 2015 Expiry date 26 May 2016 Test Result Pass Odometer reading 108,861 miles MOT test number 3170 6162 5155 Advisory notice item(s)
Nearside Steering rack gaiter deteriorated (2.2.D.2d)
Test date 1 May 2014 Expiry date 26 May 2015 Test Result Pass Odometer reading 103,416 miles MOT test number 4499 0152 4105 Advisory notice item(s)
Play in steering rack inner joint(s)
some suspesnion bushes perishing but no play
small amount of grease around balljoint rubber
Test date 1 May 2013 Expiry date 26 May 2014 Test Result Pass Odometer reading 98,095 miles MOT test number 6655 4162 3169 Advisory notice item(s)
chip on windscreen
n/s/f tyre worn outer edge
some suspension bushes perished but have no play
Test date 27 April 2012 Expiry date 26 May 2013 Test Result Pass Odometer reading 92,066 miles MOT test number 1664 6841 2150
Test date 27 April 2012 Test Result Fail Odometer reading 92,066 miles MOT test number 6680 6851 2127 Reason(s) for failure
Nearside Front Track rod end ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.2.C.1c)
Test date 11 May 2011 Expiry date 26 May 2012 Test Result Pass Odometer reading 85,617 miles MOT test number 5975 9153 1191
Test date 11 May 2011 Test Result Fail Odometer reading 85,617 miles MOT test number 4996 7173 1104 Reason(s) for failure
Rear fog lamp not working (1.3.2b)
Test date 18 May 2010 Expiry date 26 May 2011 Test Result Pass Odometer reading 77,160 miles MOT test number 8425 2813 0128 Advisory notice item(s)
chassis and underbody has been undersealed
play in both sides of inner rack
front pads starting to look low
noise on heavy brakeing o/s/f unable to find cause
Test date 13 May 2010 Test Result Fail Odometer reading 77,160 miles MOT test number 7517 9343 0182 Reason(s) for failure
Nearside Front Steering rack gaiter split (2.2.D.2d)
Nearside Headlamp aim too high (1.8)
Offside Front Headlamp aim too high (1.8)
Offside Front Steering rack gaiter deteriorated (2.2.D.2d)
n/s/r tyre borderline pass and perishing
o/s/r tyre low
Test date 27 May 2009 Expiry date 26 May 2010 Test Result Pass Odometer reading 70,635 kms MOT test number 3815 8704 9197 Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Test date 20 June 2008 Expiry date 30 June 2009 Test Result Pass Odometer reading 69,251 kms MOT test number 1144 0267 8160 Advisory notice item(s)
Test date 11 June 2007 Expiry date 30 June 2008 Test Result Pass Odometer reading 67,550 kms MOT test number 7628 1266 7104
Test date 19 June 2006 Expiry date 30 June 2007 Test Result Pass Odometer reading 62,958 kms MOT test number 6634 9047 6142
Test date 14 June 2005 Expiry date 30 June 2006 Test Result Pass Odometer reading 60,369 kms MOT test number 7720 9536 5192
Test date 8 June 2005 Test Result Fail Odometer reading 60,369 kms MOT test number 5642 3915 5116 Reason(s) for failure
Rear fog lamp tell tale not working (1.3.1b)
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Steering rack damaged and unserviceable (2.2.C.1d)
Parking brake: efficiency below requirements (3.7.B.7)
And heres some pictures
Powertrain
Engine 2.4 L 22R I4
Dimensions
chip on windscreen
o/s/r tyre low
