a pair of Dellorto DHLA 40 carbs. for rebuilding.fully stripped nothing is seized so you know that these are good to build back together. I was going to get aqua blasted. pretty much everything bar trumpets are there. now no longer needed as plans have changed.
(floats have the pins taped to them as wanted them to stay with correct float in case you were wondering what that's for )
£100 the pair. collect from London/kent, can be posted for £12 extra. pm if interested-cheers
