Oct 20, 2016 10:28:16 GMT
From cold before work and then when stood all day after work. Keeps cranking then finally with foot on throttle it goes after maybe 30 seconds of cranking.
I want to sort it before it gets any colder, any ideas?
Davey
Resident Tyre Nerd.
Oct 20, 2016 10:47:53 GMT
Sounds like an injector too me. Does it run okay once started? Can you do a leak off test or get someone to? Glow plugs can cause an issue too but not normally so bad.
Oct 20, 2016 11:05:59 GMT
Sounds like an injector too me. Does it run okay once started? Can you do a leak off test or get someone to? Glow plugs can cause an issue too but not normally so bad. Runs fine apart from a squeek (fan belt??) Will see if I can get someone to do it, I don't do mechanicals lol
Kieran
Oct 20, 2016 12:41:26 GMT
Sounds like an airleak, allowing diesel to run back to the tank.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Oct 20, 2016 13:40:27 GMT
you know to turn your ignition on, let the glows plugs relay click then turn the ignition off and then let them click again and then start the car to find out if its a glow plug issue?
Oct 20, 2016 14:27:06 GMT
you know to turn your ignition on, let the glows plugs relay click then turn the ignition off and then let them click again and then start the car to find out if its a glow plug issue? No I didn't. Will try it when I'm finished 👍🏻
Oct 20, 2016 15:50:50 GMT
will just double warm the chambers up before you fire up.
Oct 20, 2016 16:43:05 GMT
will just double warm the chambers up before you fire up. Seemed to work. Still took a little cranking. The mornin will be the test. Is that indicating glow plugs need doing then?
Oct 20, 2016 17:02:12 GMT
warming the chambers up will help with whatever the problem is but it could also indicate that your plugs might be on their way out. what mileage do you have on the car?
you can test your plugs wih a volt/amp meter though its just as likely to be a leaky or defective injector too
Oct 20, 2016 17:31:01 GMT
warming the chambers up will help with whatever the problem is but it could also indicate that your plugs might be on their way out. what mileage do you have on the car? you can test your plugs wih a volt/amp meter though its just as likely to be a leaky or defective injector too Mileage is just coming up to 80500 Also there has been a small leak on it for a while. Maybe a two pound size patch on the floor when it's been parked up.
Oct 21, 2016 10:50:18 GMT
will just double warm the chambers up before you fire up. Seemed to work. Still took a little cranking. The mornin will be the test. Is that indicating glow plugs need doing then? Did it this morning and if was same
