So had a garage clean out! In total I have the following left, all from silvertop Zetec unless stated otherwise:
- cam cover - painted burgundy and fitted with a different breather. £20
- standard cam cover. £10
- black plastic cam cover - don't know where this came from! Blacktop maybe? £5
- Ford alternator. Untested by me, no reason to suspect it's duff. £10
- Zetec 1.8 flywheel. £10
- Zetec 2.0 cams and pulleys. £25
- sump, baffle plate and oil pickup. Sump looks to have been repaired (see the 'gack' on the LH side). £free
- Ford inlet manifold and throttle body. £10
- Fiesta XR2i instruments. £10
- crankcase breather, 13mm fitting. £2
- AN8 Jaz fuel tip over valve - as new in packaging, £20 from Rally Design, £5 to you
Collection on anything from PE32 1HH near King's Lynn, although I'm driving to the Lakes next Fri and back Sun so could maybe drop off enroute. May post smaller stuff at buyers expense.
Cheers,
Si
Cheers,
Si
