Anglia68
Powered By Boredom.
Excellent job by the two of you. Looks really good and solid now and I'm not surprised your mate is buzzing, who wouldn't be? Good luck with the rest of the work and well done for helping to save another Anglia.
that s what mates are for , i help jimmy he helps me , quicker with the 2 of us to bounce ideas of each other s , a few hours here and there makes a big difference , as does jimmy haven everything cleaned and ready to start , cheers
i did nt realise how expensive repair panels and panels are for anglia s mega dear
well my self and jimmy done a bit more on his wee anglia cut cut cut grind lol jimmy grinding away ole paint to find more rot then folded some of the door skin back to repair the frames
Looking good. Where do ye get the repair panels for it?
i don t no jimmy gets them i l find out for ye, but they are quite dear . the rest i make up as i find them , better fresh metal , than rot under the filler , cheers
Ya tell me about. Have 1 stripped at work the last few years needing a few repair panels. Original one owner irish car
pics please where did it come from in ireland
team deville ford panels cheaper express steel panelsmore expensive
well to day my self and jimmy started on ps , 2 wee bits to be done on ds , later on . well jimmy and his friend moved the anglia over and cleared the garage , surprisingly the ps i very very good , and rotten too. but in brilliant nick ,if you look past rot . well 2 fresh heads and away we went .starting of with the front strut tower , the same as the ds , awee look over to the ds and its looking neat wee bracket to be welded on side of spring hanger jimmy takes out cancer or tin worm and cleans it all up , then a coat of our favorite stuff metal treatment first coat of metal
welds dressed up and second metal bracket remade plugged seamed other side of inner wing chassis leg
2 areas around the strut towers wher badly patched up over the rot so jimmy and my self cut it all out and jimmy spent some time cleaning up all around them seam welded and plugged on to double skinns hard panel for me to make so we both made it up in sections , and we think it turned out nice jimmy was well pleased even made a coffee down the side of the tower had to be cut out too , with all these panels interlocked there is some strenght in it now
pics please where did it come from in ireland team deville ford panels cheaper express steel panelsmore expensive I'll try get pics. It's a roscommon car
jimmy has a spare quarter panel repair panel if your interested ill send ye his number
not bad for a car port at the side of jimmy s house
seems in the wrong place , no one restores cars on here , or i ve ratteLED cage, CAR BEING RESTORED NO ONE GIVES A .
