boyd
Sept 23, 2016 17:24:29 GMT
Have refurbed the wheelarches on 2 of my Mercs Now all 3 need doing . Previously used aerosol filler primer which is curse word hardly fills at all I am after doing bit next time with my compressor and gun to shoot it on a bit thicker to fill the grind marks etc and where the metal is lower as a result of grinding the rust out My compressors a 2.5Hp wolf ( Aldi ) 9.5CFM I remember having a capri years ago which i prepped for respray and then had it blown over the Sprayer felt a dent which i hadnt got right got his gun out with some gloopy filler in it and shot it all over the dent then rubbed flat looked so quick and easy so any suggestions for
a What Primer Filler to use ?
B with what gun ?
C Other tips advice
Thanks Boyd
Committed Mercedes Man
W124 In Intensive Care
W202 1997 C240 Hers
W210T 2001 The Daily Bus
w208 1999 CLK430 V8 for the weekend
Sept 24, 2016 19:51:42 GMT
I'm not a painter but I've done lots of small repairs so this is my advice With your compressor you're going to need a small "blow in gun" there quite cheap to buy and you can get them off eBay for £20 or less The high build primer you will need to get from a car paint shop there's lots of makes but it's all pretty much the same thickness and it will be a paint and hardener that mixes aprox 4:1 It won't cover dents and if you repair scratches are deep then it will need 3 or 4 coats and lots of flatting down after to loose them (it's not a miracle worker)
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
johnd
Sept 25, 2016 19:17:02 GMT
Just use bodge?
Sept 25, 2016 21:17:28 GMT
I've always used Lechler 2k filler primer. IMO you need to use a 2K filler primer (in that it goes off via a chemical reaction rather than evaporation of solvents) because you really can't get a decently thick layer to dry properly in a reasonable time with a 1k paint. 2k paint does have some health risks and you should really wear an air fed mask etc. Most people don't and they have no issues, but there is an outside chance that you'll react to it so look into the risks. With it being a 2K paint, once mixed you'll obviously have to use it within half an hour or so and then clean the gun out properly.
Since you'll be sanding it, surface finish isn't that important, just use any cheap gravity fed gun. Mix it 4:1 with the hardener and see how it goes, if your gun struggles, add a little bit of thinners - a bit goes a long way, you shouldn't need to add more than 10%.
Like discostew says it doesn't work miracles and it can sink and reveal scratches over time if you put it on too thick and rush it. Ideally you'd feather out anything obvious and get it all pretty much 99% there before using it, but in my opinion it's absolutely essential if you want the final job to look good.
dan
Sept 26, 2016 10:11:15 GMT
I used Max Meyer 3300 2K filler primer and it is a bit thicker than paint so needed a larger needle in the gun. I accidentally left a 30p filter in the gun so got a rubbish finish. It was disappointing though not the end of the world but had to be blocked down. I also left it too long to clean out the new gun so that was trashed as well. 2K is very nasty stuff so make sure you have a mask, disposable paint overalls, gloves etc. Some things are best left to the professionals
Last Edit: Sept 26, 2016 10:28:04 GMT by dan
How Do I Shoot Filler Primer ? ChasR
@chasr
Club Retro Rides Member 170
Sept 26, 2016 10:35:05 GMT
Definitely regarding 2k. Sure, a few people are fine and I know of a few, but I also know of the other half who are not, and one who is no longer here to tell the tale (went in his 50s and was a very decent bloke ![:(](//storage.proboards.com/forum/images/smiley/sad.png) ). After all, 2k has cyanide present in it, well isocyanite to be precise, probably a little worse than what the average fag has in it.
Last Edit: Sept 26, 2016 10:36:51 GMT by ChasR
Sept 28, 2016 12:24:34 GMT
This stuff is the way to go. get some Durablock sanding pads to do the sanding. Youtube covers the use of both those products. ![](http://www.evercoat.com/cache/ex_q75_w550_h550_images_ePIM_original_100712-Feather-Fill-quart.jpg)
