Hi all,
Looking for some help with clutch selection please. Does not need to be anything fancy as power is not big so looking for something off the shelf if possible.
I have a flywheel and clutch cover but need the clutch plate itself.
It’s a type 9 pattern so 1" x 23 spline
It needs to be 220mm overall diameter
However the one I tried, the mk1 mondeo cutch is not suitable as the hole in the clutch cover is only 135mm and the mondeo clutch centre is too large with not enough friction material.
the clutch plate will need to fit a 135mm max centre so around 40mm friction material width
So I need a clutch like the picture below but with the type 9 pattern so 1" x 23 spline. You will see the mondeo clutch on the right and the width of the friction material is not as much as the one in the photo, the one in the photo has the wrong spline pattern though.
Thank you for any help.
