Oct 30, 2017 18:23:55 GMT
I've just realised I didn't add the all-important second half of my engine mount story in my previous post.
Recap...
Changed the engine mounts, which was a total mare. Drove over to my friend's place to do it. Only an hour's job and his car space was free for a couple of hours before he desperately needed it back. One mount had completely separated, and to get the upper bush plate out of the bracket required us to remove the bracket and apply a bit of vandalish violence to the mounting. It had to be savaged out with angry tools. Smashed. Murdered. Mutilated and torn from it's resting place. But it eventually came out.
Part 2...
Having got it out, I then realised for the first time that the replacement engine mounts, listed specifically as 1973 Scimitar engine mounts by a reputable supplier, were about an inch thicker. I had assumed my old ones had merely crushed down over the years, but looking at them next to each other the new ones were obviously much thicker. It suddenly didn't look good. We had about an hour left so we set about trying to get one of the new mounts in. We tried everything. We swore lots. We lost skin. We hammered, we raged. We sent extreme tension farts rocketing into the wet tarmac that were barely masked by the screams of exertion that accompanied them. The new mounts were not going to go in. Not by any means. No amount of swearing. No amount of farting.
With ten minutes to spare before my mate's drive needed to be put to more pressing use, we had to give up. I then had to lash all the butchered parts of the old, vandalised, violently dismembered mount back together using evostick, cable ties and a sports sock, and stick it back in so I could drive the car home again.
Two days later the correct mounts arrived and it was the ten minute job it should have been in the first place with me doing it alone in the street outside my house. The lesson learned is not to use your mates driveway, as the job will always go wrong and end up being a nightmare for both parties in unanticipated ways.
Ehhhhh. Hnnnnnnng.
I have an irritation.
I've tried a Roadkill fix on something, and I think I've made it worse.
A few weeks back I started smelling coolant once up to temp and driving along.
When I had time to inspect it, I realised it was the top hose leaking at the join to the rad.
I suspect the Samco Silicon hoses on my car are a tad too big in diameter for my car. They are all a tad baggy.
The leaking join had previously been treated to two broad band hose clips and tightened up.
But here it was leaking again, and quite badly, so last weekend I had it all off to inspect the rad for holes, cracks, corrosion at the port. It all looked good.
So I decided that I'd be inventive, and I put a ring of chemweld stuff around the rad port so that as well as my two clips, the end of the hose was butted into the chemweld which would then set hard adding an extra discouragement to escaping pressure.
Drove it around, Kept checking it. No steam escaping. All good... I thought.
car has been parked for the week. I just decided to grab an hour for a quick drive. Got to the car. Dry road. Wet patch behind drivers wheel. Not dog pee.
A quick look and feel around revealed it has been steadily coming out of the upper/return hose joint, which was wet on the underside.
It must have had residual pressure slowly blubbing it out for a while, and some of it had gathered in the tray below the rad, and then dripped out onto the road.
So... I haven't solved it, and now I have a ring of hardened chem-weld to crack off again. I knew it was a stupid idea when I did it, but sometimes I can't help myself.
But hey ho. Problem still unsolved. Everything has to be pulled and looked at again, and I probably ought to order the right diameter hose if it refuses to tighten.
Here's what I'm wondering though... has my coolant pressure increased to the extent that it's just finding the weakest point to blow because I have a problem elsewhere (cracked head gasket for example)? That's my current worry... that I'm trying to fix an annoying joint leak when actually the joint leak is telling me I have a bigger problem.
It just seems odd that it will not go away.
I just topped up the coolant, tightened up the hose clips even more, dried off the join, and went for a drive to buy new coolant.
It's still getting wet under the join, even after the umpteenth tighten.
Last Edit: Nov 3, 2017 18:55:19 GMT by Deleted
Rob M
Club RR Member Number: 41
This was the NAUGHTY CORNERRob M
@zeb
Club Retro Rides Member 41
If the hose is too big no amount of tightening will seal it. You are not trying to prevent cold, still water getting out you are trying to prevent f*****g hot pressurized water from escaping and you simply cannot. Been there done it! Unless the car is really running hot and overheating I don't see the headgasket being the issue, could be wrong but I've had 6 of them and have never had head gasket issues but have had to keep on top of the cooling systems which, if looked after, work absolutely fine and dispels the annoying myth that they are cars prone to overheating. Good luck! ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Last Edit: Nov 3, 2017 18:24:04 GMT by Rob M
Ha, yeah... mine doesn't overheat at all. It does get up to heat quite quickly (about 10mins from cold), but then it just sits there once it's arrived at temp.
I don't know for sure that the hoses are definitely too big. The car came with them already on though so I have no idea if they were made for the Scimitar or were just hanging around in a previous owner's garage. A set of blue Samco hoses, so not original parts. It's not like they're waggling around like a wizard's sleeve on a sausage, but they don't seem particularly snug either.
I really ought to just replace them all.
I don't know why but I've spent my entire time with this car convinced it either has, or will develop a head gasket problem. I don't really know why though. It doesn't show any signs of HG problems, yet it's always at the back of my mind.
Last Edit: Nov 3, 2017 19:16:07 GMT by Deleted
Nov 10, 2017 16:58:30 GMT
I had a bit of a 'self-employed, no income incoming' crisis recently and had a knee-jerk reaction to that which made me think "SELL THE CAR IMMEDIATELY". I didn't. I calmed down and some work has started to come back in again. But now, in a more rational state of mind, I'm still lingering on the idea that I've done some work to my Scim and had some fun driving it and owning it, but maybe it's time to sell it and renew my ambitions. I still miss the Humber SuperSnipe painfully, and it can never be replaced - especially by another stock standard Super Snipe - but I'd like to get back into old metal saloonery. So I've recently latched back on to an idea I had a while ago, which is to buy a Rover P4 with a straight 6 engine. Keep the running gear stock but see what can be done to tease a bit more power out via modest means, and convert it visually into a PanAmerican Rally tribute car... So, one of these (of which there are a few around in suitably non-pristine condition for quite cheap) and then raise the hide, slap some gnarly fat off-roady tyres on it, do some contrast painting and some rally lettering, maybe acrylic side windows, and other little touches, and a straight through exhaust and end up with something in the approximate ball park of one of these sorts of things .... I just need to sell the Scim first. I'm a one-car-at-a-time bloke. I'm not 100% sure I want to get rid of it, but then I'm also not 100% sure I want to keep it. It never was purchased as a long termer, it was only ever a consolation for losing Monty. A weekend of deep thought lies ahead.
Smiler
Nov 11, 2017 10:40:37 GMT
I'm a one-car-at-a-time bloke. I wish I could manage to stick to that! I really thought I was going to manage it when the Escort was nearing the end leaving me with just the yellow Scimitar, but then my friend offered me his Omega converted black Scimitar for peanuts and I couldn't refuse, even though it is in a right state.
Last Edit: Nov 11, 2017 10:41:07 GMT by Smiler
Rob M
@zeb
Nov 11, 2017 12:07:03 GMT
I had a bit of a 'self-employed, no income incoming' crisis recently and had a knee-jerk reaction to that which made me think "SELL THE CAR IMMEDIATELY". I didn't. I calmed down and some work has started to come back in again. But now, in a more rational state of mind, I'm still lingering on the idea that I've done some work to my Scim and had some fun driving it and owning it, but maybe it's time to sell it and renew my ambitions. I still miss the Humber SuperSnipe painfully, and it can never be replaced - especially by another stock standard Super Snipe - but I'd like to get back into old metal saloonery. So I've recently latched back on to an idea I had a while ago, which is to buy a Rover P4 with a straight 6 engine. Keep the running gear stock but see what can be done to tease a bit more power out via modest means, and convert it visually into a PanAmerican Rally tribute car... So, one of these (of which there are a few around in suitably non-pristine condition for quite cheap) and then raise the hide, slap some gnarly fat off-roady tyres on it, do some contrast painting and some rally lettering, maybe acrylic side windows, and other little touches, and a straight through exhaust and end up with something in the approximate ball park of one of these sorts of things .... I just need to sell the Scim first. I'm a one-car-at-a-time bloke. I'm not 100% sure I want to get rid of it, but then I'm also not 100% sure I want to keep it. It never was purchased as a long termer, it was only ever a consolation for losing Monty. A weekend of deep thought lies ahead. Do it. Life is short, scratch the itch. Your idea sounds really good, especially the idea of tuning rather than transplanting, that would be very interesting. What could go wrong? ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Nov 25, 2017 19:06:30 GMT
Father Christmas came a little early to my house. He was muttering something about "Black Friday"... Only trouble is they keep falling off as I'm driving along. I need more sticky fixers. Edit: I had a devil of a job sourcing a set of tyres...namely due to the increasingly less well catered for 14" rim size. I've been wanting to change my tyres since I got the car. The tyres it came with are Winda WP16s... a budget tyre from a Chinese manufacturer. I'd never driven a Scimitar before so it's been hard to determine whether a change of tyre might affect the ride positively, or whether my car is just a bit old, on hard springs, and lacking in comforts ... making it feel harsh. More importantly though the front 205/70's nudge the wheel arch when I'm turning towards full lock. So I've been hankering after something a bit narrower that wont offer such a prominent shoulder. The Windas are not listed as a van tyre, but they sure do drive and look like a van tyre to me. I also knew I wanted fat Hercules on the rear. I like Hercules tyres. I've fitted them to a few 70's and sometimes early 80's cars. I like the way they look... basic and unfussy but with raised white letters for that little visual nod to the era. Sizes for 14" Hercules are limited. I didn't want to end up with an obviously raked look. So I was looking for the right tyre size balance between wider back tyres and my need for a skinnier set of fronts, but with similar diameters. Then I found Openeo offer BF Goodrich at about £80, but again only in a couple of options for 14", so the search got even more complicated. So I've spent weeks now in little moments of downtime, going backwards and forwards to my tiresize app, between the Hercules and BF options, then seeing whats out there for compatible fronts (an ocean of 14" van tyres basically) and hadn't found the right combination that I could press the button on. So eventually I decided I'd have to relax a bit about a bit of rake (it's still not much... just under an inch difference front and back) and as North Hants were going to deliver my Hercules I thought I may as well go with their option for the fronts too. Didn't want white walls, but they were a good price and the right proportions, so I decided to just end the constant searching and go for them. Literally two minutes after hitting the buy button, somebody mentioned they have Uniroyal Rainsports on their Scim in the exact size I wanted in the first place, and a bit cheaper than these Galaxy whitewalls. The Uniroyals never once came up in my searches. Not bloody once. DAMN YOU TIMING.... DAMMNNN YOUUUUUUU
Last Edit: Nov 25, 2017 20:11:40 GMT by Deleted
Well, it's cold, it's nearly Christmas, it could rain at any moment, and these are short dark days. So I decided for once, I'd hand over a bunch of simple jobs to a local garage. They can get the car up on the lift and do them all at once with everything they need close to hand. I felt I'd rather pay than do it myself for a change, plus I don't like doing brakes because I have this nightmare scenario where I cause a crash and it turns out to be a fault of the brakes and then I have to explain to a judge, whilst in shackles, that I did my own brakes and no I'm not qualified and oh dear it's manslaughter, willful neglect, 10 years. So I don't do brakes. I wanted all fuel line replaced from tank to carb. I wanted everything that could be greased to be greased. Trunnions inspected and then greased, and just... everything greased. Everything. Even the headlights, the seat leather, and the wiper blades. I wanted my rear brake cylinders and shoes replaced, the brakes all checked out and new brake fluid. I wanted them to stick my new tires on, because I'm just ITCHING TO GET NEW TIRES ON. Last week, I went to the garage, took my list of things that need doing and asked to be booked in whenever they were able to get it in and do it. "We can do it Monday" Okay, booked it for Monday. Took the car out for a drive on Sunday, culminating in me driving in to Brighton town centre, midday, up the busiest street at busy Christmas shopping peak. Lots of traffic, lots of pedestrians, lots of people everywhere. Car starts jerking, sputtering, and then dies. Right hand lane of a main/busy, but also narrow road. Wont start again. Cars backed up behind me, the only possible escape from clogging up the town centre entirely was an uphill push across the left hand lane and round a left hand corner into a side street. Fortunately a bunch of lads all ran over and helped to push me and if by any chance any of you are reading this... much appreciated. I was too concerned about the billowing noxious green/grey smoke pumping out from under the left hand sill to really thank you properly for your generosity. Grabbed the fire extinguisher, got under the car, but before I could figure anything the smoke, thankfully, faded away. Very lucky, considering it seemed to be coming from right by the fuel line underneath a fibreglass car. There's not much room under the car, so aside from feeling blindly round inside the sills and round the the chassis rails, I couldn't get underneath it to see anything at all. I felt along a bunch of wires, and they felt okay (no hot blobs of fizzing mess). I checked under the hood, I checked as much as I could. I had to conclude it was either a short circuit or the fuel pump had burned out. Changed some likely fuses because it was all I could do with what I had available. Tentatively turned the ignition to see if it had magically cured itself, and noticed there was no fuel pump burble. It was the fuel pump. You can see where it splodged out in this shot... Tried everything I could think of to obtain a new fuel pump. Phoned round suppliers... all closed. Phoned my mate... miles away and no spare pump anyway. Left futile messages on car forums and social media... nothing. So for the second time since I've had this car, it has chosen to curse word out on me literally moments before it goes into a garage, and it has crapped out in a manner exactly matching the work I'm asking to be done. First time booked in to have the brakes improved pre-MOT, and the servo died on the way there. This time fuel lines to be replaced... and the pump dies. Had to face the utter humiliation of calling the RAC to come and get me. RAC man was a top bloke though. We had a good chat and a good laugh about some local folks we both know. Car dropped at garage. Picked it up today with all new fuel line fitted, new pump fitted, new brake cylinders and shoes and new fluid. Greased where needed, but sadly still no tires on. £90 lighter for a Gold-Flo (whatever THAT means) Facet pump... the only one locally that would be a straight swap with the same bracket etc. There are cheaper Facets I could have ordered,but I really didn't want the car sat in the garage while I waited for it be delivered, just to save £20-£30 on the RRP. £150 garage bill. It's still going to cost the best part of £100 to get the tires on, so it's been an expensive month for the Scimitar... offset I guess by the fact it hasn't cost me anything at all for a good many months now. I hate how everything starts crapping out in the winter months though.
Eh, this weather. This rain. Please stop. I really want to get my car out for a long drive. Don't want to do that on rain sodden streets though because I planned to update/refresh my underside protection this summer before the winter sets in and I didn't get around to it... so the idea of driving a car along salty seaside roads and spraying salty road water up into the chassis extremities doesn't feel like a smart thing to do. Also... just had the brakes done and they need testing, but I want to give the car a good long run at high revs, and suddenly reaching an unexpected traffic build up on wet and possibly icy roads with untested brakes is also not on my wish list. The reason I want/need to give the car a good run though is that lately all I have done in the car is very short, very local, very traffic heavy trips around the local neighbourhood. What I discovered the last couple of times though was some mist/vapour/emission from the oil filler/breather cap. Not plumes of the stuff, but more than I've seen before on this car. Might just be condensation evaporating and made worse by the infrequent short trip nature of the car's use over the weeks. Could also be valves, valve guides, worn or cracked rings or a failing HG. Oil looks clean, doesn't overheat. Doesn't seem to be losing coolant now I've found a few leaky hose joins and re-fitted/re-tightened them. Need to give it a good long run first and foremost to see if it simply clears as cold weather condensation build-up. If not, I need to start looking deeper. With luck it'll be valves related. In other news... I finally got rid of the awful cheap chinese van tires and put my tire of choice on the back... But I also put some white ringed tires on the front which look absolutely hideous... I wasn't ever planning on fitting the white rings outward facing... they just happened to be the right sized tires from the same vendor (Northhants) and are an increasingly rare 14" car tire in the size spec I needed to balance out the rears. Right price point, discounted for black friday and easy to deliver alongside the Hercules rears. So I got them with the intetion of fitting them black sides out. Then at the last minute the tire fitter said "Do you want these white rings on the outside?" and I thought "Why the hell not... stick em on the outside". Instantly regretted that split-second decision. My god they look utter gash.
Last Edit: Dec 14, 2017 13:24:59 GMT by Deleted
Edit: Wrong topic
Last Edit: Jan 10, 2018 22:34:14 GMT by Deleted
Eh, this weather. This rain. Please stop. I really want to get my car out for a long drive. You'll have to do what I do. 05:00 on a Sunday morning. It's the only time I can get above 30kph! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
The Doctor
Club RR Member Number: 48
This was the NAUGHTY CORNERThe Doctor
@thedoctor
Club Retro Rides Member 48
Dec 11, 2017 21:55:41 GMT
I'd say your friend has a blown headgasket on his car. Mayo underneath the oil filler cap could be condensation from short runs, but together with pushing water out via the rad is a pointer for a BHG to me ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Dec 11, 2017 23:18:01 GMT
Yep, that was exactly what I thought when I saw it, but he didn't seem to want to entertain the notion. Suggested I didn't know what I was talking about and that I worry too much. Well, he got me there, I do tend to worry about every possible potential problem with my car, but still... some things do seem to be as plain as day to me, and this was definitely one of them!
PS: I laughed hard at your sign-off line about the pedal bin.... = )
Dec 11, 2017 23:25:43 GMT
In other news, I couldn't resist the urge to go for a drive today. So against all sensible considerations, in sleet and sub-zero temperatures, I went for a hoof up the country roads in the Scim on my brand new box fresh tyres.
I damn near lost it completely giving it a little too much encouragement on an icy uphill bend. It was a left hooker and I was going slow around a tiny island, so tried to accelerate in second to see if I could tease the back end out a little bit. I actually teased it out a lottle bit and it almost overtook me, and then correcting that was a whole other heap of mess the other way... it just snaked wildly up this twisty little road until I eventually had to accept that I wasn't Colin McRae and the best course of action would be to stop touching any more pedals until the car had come to a stand still once more.
It was damn scary, but also good fun... afterwards... when I'd changed out of my underwear.
This was the NAUGHTY CORNERglenanderson
@glenanderson
Club Retro Rides Member 64
Just found this thread. Duly bookmarked. 😃
Have you considered Lucas L691/L692 rear lamps? They’re suitably period and a bit larger than the Land-Rover type ones you have at the moment; but not as large and modern looking as the other Scimitar you pictured earlier.
I agree that your mate sounds very much like he’s got a failed head gasket. If he’s been driving it like that enough to think it’s normal he probably has a cracked head too. I’d suggest he knows less about rebuilding engines than he’d like you to believe.
And my final contribution for tonight; from your description, I’d say 100% that Lurch is autistic. Autism is a spectrum, and where individuals are on it varies widely. I am certain your confrontations have been as confusing for him as they have been for you. One of the areas autistic people struggle with is reading the body language and non verbal cues of non autistic individuals and the inverse is also true; they are often very poor at matching the non-verbal signals they send out with the meaning they’re trying to express. This, combined with another common trait of lack of social filter means that they are often misinterpreted as rude, arrogant, condescending etc. Him continuing to verbalise his thoughts after you’ve finished is another sign, one that suggests the interaction has happened at a pace he has not been able to keep up with. Are you still having problems with him? If you are, then I can guarantee that there are better ways of resolving the issue than physical confrontation. If it escalates like that again, I’d urge you to try and restrain yourself, because people can do the strangest things in fear. Obviously, just because he’s autistic, doesn’t mean he can’t be an utter bell end, but you’ll never find out by shouting and shoving.
Just found this thread. Duly bookmarked. 😃 Ha, you are clearly a glutton for punishment. My progress thrrad is actually more like a diary of anecdotes from the banal side of life. Most people Ignore it these days. "Have you considered Lucas L691/L692 rear lamps? " I don't recall the number, but I have a classic car fittings catalogue I picked up at the Revival which has the whole range of Lucas lamps, and others, available. The reason I didn't choose anything more suitable out of the catalogue though is price, plus the ability to see for myself what they look like before buying. In short, these lamps cost me absolutely peanuts and I wanted to work with peanuts rather than spending loads of money on the job before I'd even tried to change them. Maybe I'll revisit it this summer, but for now I've lost interest in the rear lights. They're round, they work. Could be bigger and made much tidier, but I quite like them as they are. "I agree that your mate sounds very much like he’s got a failed head gasket" Trouble is, he probably won't admit it. It will upset the status hierarchy of our friendship. That's the last time his car will be out until June next year., so I'll have to wait until then to find out. "And my final contribution for tonight; from your description, I’d say 100% that Lurch is autistic" Blimey, you have delved back! Yes, its highly likely. If he is, he's also self employed, owns and manages to operate a car and navigate roads, signage systems, erratic and unpredictable traffic, and has to interact with varied people in dynamic environments. So if he does have some cognitive glitches they are not so extreme that he is unable to function as a member of society, and therefore he needs to understand the rules of social interaction. There does have to come a point in the sliding scale where people are given license to behave the way they do because they are autistic, and others are able to comply and function and are therefore just behaving like dicks because they don't like cars parked near the entrance to their garage. If the dickish behaviour is a by-product of a degree of autism, he's a grown man, clearly capable of learning, and he needs to learn. Better to learn from me as I have some self-restraint and awareness, than to learn from somebody who will simply knock him out... Like the Mercedes driver in my anecdote. Anyway, I'm pleased to say that since I confronted him he has stopped... As far as I know.... Taking vindictive action, and seems to have accepted that somebody is always going to park there. It doesn't prevent him getting in or out... It's the rest of us that can't use the space as a temp loading bay that suffer.
Last Edit: Dec 12, 2017 8:47:23 GMT by Deleted
Dec 12, 2017 16:43:23 GMT
Well, I'm going to be back to posting car experiences and updates here on retrorides again from now on. When I got the Scim I was seduced by the lure of a dedicated Scimitar forum and being a one-track kind of person I switched all of my updates over there. I don't really like spreading the misery over too many places, I prefer to have it all in one place. A lovely bunch, the Scimitar crowd, and very helpful. However, I never really felt like I fitted in there. It's not really a place for the kind of inane jibber-jabber I love to type. It's not a place for the unrepentant halfwit to ask stupid questions and blather on about any old tosh. Unlike Retrorides ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) I think the value and strength of a place like this is that there are all sorts of people with all sorts of competences doing all sorts of things. There just isn't really time to pick one thing out and battle to the death for technical knowledge supremacy. It just doesn't feel at all important to be a proven expert. In my experience the more technically able somebody is here, the more humble they seem to be about it. I'm not a serious Scimitar owner, my car is a bit of a dog compared to the dedicated Scim owners' out there... purely because I prefer dogs to immaculate and correct classics. I could quite easily sell this on tomorrow to buy a Rover, another Humber, or almost anything that takes my fancy... if it's a dog. I'm not a Scim fanatic, and I think that's the key difference between me and a club for Scim owners. I lack the fanatical devotion to preservation. So I've downloaded my progress thread over there and bid a fond farewell, and from now on my updates will be posted here again, as before. Starting with... I'm going to have a look into the smoking oil breather cap issue over the christmas break, weather/time permitting. I was surprised when downloading my progress thread that I had previously made a comment regarding the *relatively* heavy breathing back in February, and had then promptly forgotten about it. So evidently it isn't a new development at all... it probably gets more visible in the cold months and less visible in the summer months. It may still yet be a result of my infrequent, short, traffic heavy local driving. It may actually be exactly what would be expected of a 45 year old Essex, I have no idea. But at this point I think it could equally be valves related so I'd rather investigate and have peace of mind. It's possibly an exhaust valve sticking. So first things first I'm going to lift the rockers off and have a finger-fiddle with the giblets and see if anything seems lose, like a rocker arm, or whether anything feels bound, like a valve stem if it's possible to check that with ease from above, and then I'll see about tolerances/clearances that can be gauged/adjusted from the top view with the heads still in place. One thing I do know, it's a curse word looking at engine stuff in an SE5a engine bay. I might need to do some sore-back-related swearing. I'll be looking into any possible action that can be taken with the rockers off and the heads still in place... whether there is any cleaning/soaking that can be done at that point to try and free up a sticking valve or de-crust a valve seat from above, or whatnot. It may well end up requiring the heads to come off. Before that though I plan to take a quick video and post it up for thoughts on the amount of breathing I'm doing. It's so slight really that it could just be par for the course, but I like to be sure. Beyond that, it could feasibly be a stuck piston ring or broken piston ring. If it came to that though, I'd have to seriously think about whether it's worth stripping down this engine fully, or whether the cost of doing that might be better spent commissioning a replacement engine. I may look further into any sound methods of tipping a little bit of something into the bores to soak through the piston rings. People used to tip 40ml of old-formula Redex into the bores and turn the engine over to move it around... but it seems that Redex' formula has changed since those days and it may not have any effect, or even have a detrimental effect to do it with the modern Redex formula. I will also do an oil and filter change though realistically it is not due for one just yet. Having realised I already mentioned the breathing in February and the response then was that these engines do tend to be heavy breathers and it's nothing to worry about, I'm less concerned about it, but the rocker cover gaskets need replacing anyway, so I may as well have a little fiddle and see what's what when I do that.
Dec 13, 2017 10:59:37 GMT
Ponderings on Tesla. I found myself watching some drag racing last night. It seems there's a car getting a lot of attention on the US drag circuit at the moment. It's a Tesla P100D or whatever they're called, and it's been stripped out inside but is otherwise stock. It's apparently doing the rounds on the drag strips and deliberately trying to pick off Hellcats to race. It trashes them all effortlessly. There's a few vids on Youtube, some of which are on the Tesla Racing youtube channel. Haven't looked into whether that's an official Tesla thing or not. The thing that struck me about it is that Musk knows how to market stuff, and he knows where the real battle for hearts and minds lies. As far as I could gather late last night this Tesla is an independent owned and run car... but I wouldn't be surprised to find that the idea, and the blessing came from tesla themselves. if Tesla can evangelise the hard core drag strip crowd by slaying their mightiest warriors, I can see a swift conversion taking place. Who wants to be fighting and losing in an arena where unrivalled speed is the sole objective. What freaks me out though is that the Tesla does it all with none of the theatre of drag racing. Its an upper mid-range executive saloon. No noise, no smoke, no decals, no character, no lettering, not fat rears, no aggression... it doesn't even need to spin the tyres to prepare.. it just sits waiting at the line for the other car to finish spinning the tires. Then it just silently pulls away. There are some cars that can just about beat it it seems... but you have to conclude that this is as far as you can feasibly take a combustion engine, and in contrast, the Tesla can simply drive off the track and be a perfectly performing road vehicle with no problems at all. When the Roadster appears those few cars that can still win will lose. It does really feel like it could be the death of an entire culture eventually. To be replaced by effortlessly fast, silent, unremarkable looking reps cars that just glide up the strip and post identical times. It's a Pyrrhic victory that nobody will ultimately enjoy. www.youtube.com/channel/UCOpdDZoLH9IDJ8IuNZzz2iQ
Dec 13, 2017 11:10:43 GMT
24 Heures du Mans?
