Mar 11, 2018 13:12:06 GMT
Had a little bit of time this morning, and an off cut of 3mm PALight big enough to use, so I decided to have a look at what might be the best way to create a console piece. It was all blind cutting by sight just to see where I ended up. The one big issue with this is that the headlight switch sits in such a way that the connectors underneath it protrude downwards in such a way that I won't be able to put them behind the panel, so I would be doing all this work only to have those dangly bits in front of it (they're not actually dangly they're rigid and can't be moved out of the way). So I think the solution will be to move the head lamp switch next to the steering column where the passenger window is currently, and then put the passenger window switch on the new console fascia. Then I'll have to blank off the hole where the head lamp switch was with a bit cut from my spare dash panel. Some curse word pics below, just so I look like the big boys. I'm not planning on having that ridiculous shaped hole for my choke cable I just wanted to cut away as much as possible so I could see. I think I will need to move the non-operational vent pods forward onto the new fascia panel. They are set too far back to co-operate with a flat piece.
Mar 11, 2018 13:21:12 GMT
Also went out for a drive this morning and whilst sitting at some traffic lights near Shoreham a silver Golf pulled up next to me and revved the turd out of its engine trying to get my attention. I paid him no mind at all, and when the lights changed he floored it and screeched off on a right hand turn like it was a rally event.
I did what I always do in those circumstances, pulled off very slowly after a brief pause, and trundled away like an old lady at 7mph.
CaptainSlog
Club RR Member Number: 180
This was the NAUGHTY CORNERCaptainSlog
@captainslog
Club Retro Rides Member 180
Mar 11, 2018 16:06:09 GMT
How about spraying the vinyl with your satin black rattle cans to achieve the same texture? Hey Captain, I only just realised what you are suggesting here.... You said spray the vinyl. I read it as spray the bare metal, which I am considering.... But, will rattle-can car paint stick to vinyl do you know/think? I've always assumed it wouldn't take paint. I think that paint will stick to the vinyl better than ali - MNSHO
Mar 11, 2018 16:30:45 GMT
Had to look up MNSHO! Oh, okay, interesting. Maybe I SHOULD try spraying the vinyl then, just to see what happens.
Mar 13, 2018 13:49:49 GMT
Creeping along slowly with my interior. I decided I need to use the original fascia piece and that it just needed cutting down a bit. Actually it slots in very nicely and I'll just need to do some creative bodgery to elegantly conceal the join between the old cut off dash in my car and the substitute cut off piece I'm replacing it with. I also just unscrewed the two massive slabs of timber that have been housing the stereo speakers on the outer walls of the foot wells, where they made an already cramped driver's footwell even more so because the timber + speaker front jutted out a good three inches, maybe more, into the footwell. Between them they weigh about 4 tonnes, so I've just added about 30BHP per tonne to my car bringing it up to an estimated 690BHP now. I also just made as precise a cardboard template as I am able to, so that as soon as the sheet material arrives I can start to hack out a fully enclosed interior sub-dash console and footwell wall thingy. I'm going to have to improvise as I go as the transmission tunnel is a wobbly wad of rattle trap insulation which I don't wish to remove, and there are a few mystery, off-true, level-steps between the tunnel and the area where the dash fascia piece needs to go. There's two months until RRG, and I'm starting to feel panicky about whether I will get everything done that I want to get done (which is hardly anything by anyone else's standards) or whether I'm going to end up skipping bits I'd really like to do in order to have something that just looks a bit better but doesn't have the switches and things I want in place, and doesn't have some smaller, lighter speakers embedded in the walls of each footwell. I think the next task before I do the interior properly ought to be the windscreen rubber replacement. Then when I've done that I can decide what to do to finish the sunroof delete, and then I can focus everything else on making a halfway decent interior. Paintwork is going to have to grumble on as the mess that it is for this year.
Last Edit: Mar 13, 2018 13:50:49 GMT by Deleted
Mar 13, 2018 15:23:04 GMT
hey, man, progress is progress...
do what YOU want to do it first...to heck with the crowds at the show. (Though I realize the motivation....)
JP
Mar 13, 2018 16:41:36 GMT
Ehhh hahaha, it's not about the crowds for me. Nobody is going to have the slightest bit of interest in my old jalopy... it's actually more of a self-imposed deadline to incentivise me to get to a certain point with the car after a very long, inactive winter of doing almost nothing to the car at all. More of an excuse to crack on and make progress.
Just been reading about fibreglass repairs on a boat website. Seems to be a lot less stressful on a boat hull... they just slap it on and rub it down and bingo... there it is.
I guess boat owners are less precious about the perfection of the hull, especially if it sits below the water line covered in barnacles.
I did make me think I should ultimately plan to glass my hole in one day though. I also have a few cracks in the roof paint which look like they might be swelling a tad after a long wet winter... which is what sent me off to the boat sites in the first place.
I should stop being such a wuss and enjoy the ability to do my own bodywork without having to shape metal and weld.
Maybe that will be my summer mission, post RRGoodwood.
Last Edit: Mar 13, 2018 17:19:06 GMT by Deleted
Smiler
Mar 14, 2018 22:08:06 GMT
Mine is covered in barnacles above the water line!...
Finally had an invoice paid. Annoyingly my days are getting filled up with requests for meetings which mean I have some materials arriving to continue working on my car, and now I don't have very many days coming up where I can do it. Always the way. On cheeky little mini-step forward though. I have a lot of useless holes in the piece of fascia I'm now going to use. But I can repurpose a few things in order to fill them. The big rectangular hole in the centre – which I assume would once have housed a couple of sliding levers – can be used as a dropdown/lift up panel to a small compartment. So I've just used a bit of offcut to try and size up what would be needed there. The roundel to the left will be a flick switch and the roundel to the right will be a small light. If done properly, maybe with a piece of metal that has some small louvres cut into it just for a bit of fancy-fancy, I think this could work as a tiny cubby hole... (obviously done much tidier than that when I do it properly ^... hopefully)
Last Edit: Mar 15, 2018 13:10:14 GMT by Deleted
Mar 15, 2018 13:09:36 GMT
there are some amazing things done with fiberglass and molds from prototype panels. Ive seen latches, consoles, inserts, ect.made up and it always impresses me...like the work this guy is doing over at migwelding: www.mig-welding.co.uk/forum/threads/my-boat-project-it-will-be-worth-it.67401/he took a discarded hulk and is making a masterpiece! His fiberglassing skills are unbelievable. very inspiring. made me think of your sunroof issues....Page 4 is where the fun really begins! You could make a prototype console panel from mdf, or simple foam panels, shape them to your liking, then using the prototype as a mold, use fiberglass for the final unit.... jP
Mar 15, 2018 15:18:38 GMT
could make a prototype console panel from mdf, or simple foam panels, shape them to your liking, then using the prototype as a mold, use fiberglass for the final unit.... Hahaha WOAH there fella.... I'm actually terrified of filling a hole. Maybe one day I'll have made enough progress that I make a fibreglass console but thats a long way off and frankly this isn't the car for that kind of involvement. A bit of half-decent bodgery will suffice here I think. My target for the interior is merely to end up looking a little bit better than the gaping hole plastered in rattletrap that I currently have.
Last Edit: Mar 15, 2018 15:19:11 GMT by Deleted
Mar 15, 2018 16:48:52 GMT
My new console material just arrived. 2x 150cm squares of 5mm Palight. I am now TWITCHING with the need to clear the kitchen table to start hacking at it. My wife keeps coming in to the room and muttering "don't.... don't you dare start doing that... do NOT do anything until we've all left the house tomorrow... I'm WARNING you", and I keep nodding and going "yeah, yeah yeah... sure... don't worry I wont" and then seconds later my hand reaches for the knives, or the cardboard template, or my selection of fixing things... because I JUST WANT TO GET SOMETHING DONE. And also... are these speakers of any use to anyone? I think they're pretty good ones. I never ever have music on in the car but I have tested them once in a while and they're in very good sonic condition. Very good sound... They're in slightly worn condition visually as you can probably see, but not broken anywhere. I don't want to re-use them because they are very big, bulky and heavy and as already stated I never play music in my car... so I intend to replace them with something smaller and lighter that I can mount into my new footwell materials and to hell with the deterioration in sound quality. If I tried to mount these they would probably bend and deform the material I'm using eventually due to the immense weight. I could bring them along to RR Goodwood if they're of any use to anyone.
Last Edit: Mar 15, 2018 23:16:39 GMT by Deleted
Mar 15, 2018 23:17:16 GMT
NOBODY HAS COMMENTED!
THAT'S IT!
I'M QUITTING!
(^ Parody post.)
Last Edit: Mar 16, 2018 0:20:42 GMT by Deleted
This was the NAUGHTY CORNERglenanderson
@glenanderson
Club Retro Rides Member 64
NOBODY HAS COMMENTED! THAT'S IT! I'M QUITTING! (^ Parody post.) Don’t let the door hit the back of your fat head on the way out. Drama llama. ** ** Parody riposte. 😉
snicker, snicker, snicker.... JP
CaptainSlog
@captainslog
BTW those infinity speakers are good speakers - 6X9s. Mount them in the back somewhere - 4 or 6 inch round speakers will do in the footwell.
oh that vid made me laugh thank you .,if you were closer i would have those speakers in a shot for the back of my 95 astra estate !
Mar 16, 2018 13:08:14 GMT
Made a bit of progress today. It's all just mocked up with whatever screws and bolts etc I have available. I'm off to the nut & bolt now to buy all the proper bits and then I have to figure out how I'm going to finish it all. Lots of rough patches and temoprary bits n bobs all over these pictures. The central rectangular panel on the console for example. I've had to bodge that temporarirly but MEIN GOTT did Reliant make anything straight? That little inlet panel is so far off square that I have made a temporary panel piece for it four times now because I just can't believe how skewed it is and I end up straightening the lines subconsciously and then it doesn't fit. The hole in the console is actually a parallelogram but with one end narrower than the other. Anyway, random shots in no particular order showing the rough mock up. I know it's nothing to the great work done here on RR... but I'm working with my own set of circumstances and this, for me, represents progress.... I'm currently at a loss as to how I can fix the choke cable. The way I'm going about doing this, I don't think the re-added centre console panel is ever going to be rigid enough to withstand repeated hoiking of the choke. I suspect I might pull the choke one day and the whole dashboard comes with it. For that reason alone I'm going to pause on this for a bit while I ponder solutions. I also wonder whether the piece of console panel I'm fitting is actually from a 5 not a 5a, because it's an entirely different texture to the rest of my dashboard material. Not that I care about that... I'm livin' in a bodger's paradise. For anyone horrified by what they see... this is how it's been since I bought the car, and I have no tools, no workshop, no extensive experience, so I'm just having to be resourceful, make it up as I go along, and my only aim is to make it a bit better than before but without damaging the car...
Last Edit: Mar 16, 2018 13:16:23 GMT by Deleted
