gazz81
Sept 2, 2016 15:43:31 GMT
Not much of project thread, but a bit of advice needed please! I have decided to upgrade the air pump on my compressor as the previous replacement has never really been up to the job. New pump arrived today, but I'm unsure where to get the correct fittings to connect it too the tank. The current pump is connected using 15mm domestic plumbing fittings, but the new pump has a more modern fitting! Does anyone know what is needed to attach a pipe to the pump, I can worry about the other end when I've got the first bit sorted.
gazz81
Sept 3, 2016 17:33:11 GMT
nobody have any idea?!!
Sept 3, 2016 17:52:32 GMT
Hi, 15mm Copper pipe as well as steel is used to do hard lines round a workshop so will be alright. Use whatever you have that will work.
Colin
93fxdl
Enter your message here...
gazz81
Sept 5, 2016 17:16:58 GMT
I have tried a 15mm copper pipe compression nut on it and its a lose fit, so whatever its supposed to be is very close to that!
tonup
gazz81
Sept 6, 2016 19:50:14 GMT
No idea, I have emailed the company I bought it from and hopefully they might know!
slater
Club RR Member Number: 78
1949 Ben Patents Compressorslater
@slater
Club Retro Rides Member 78
Buy a set of thread gauges and a vernier and measure it. Once you know the details the information on all types of thread and fittings are avaliable online.
As said it looks like a JIC but you will need to measure the size and look it up.
gazz81
Sept 7, 2016 13:08:45 GMT
on the vernier it reads 18.79mm or 0.740 inches
gazz81
Sept 12, 2016 18:25:32 GMT
I have been thinking! As previously said, my existing pump is connected using 15mm copper and compression fittings. Also as previously mentioned, I have tried a compression fitting on the new pump and its sort of a lose fit. ( It won't push on, but threading it won't tighten up, just slips on the thread) If I cleaned the paint off and bought on of these fittings, would soldering it on be a viable option?
Sept 12, 2016 18:29:42 GMT
Sounds a bit iffy to me . I would tend to think that even if it didnt blow off immediately that it might after a while .
Sept 12, 2016 18:31:30 GMT
Sept 12, 2016 19:17:14 GMT
Hi, That fitting in the head of the compressor is for use with a flared pipe. Try taking the fitting out of the head and start from the head itself. Or take it to a hydraulic company and see what they suggest.
Colin
Last Edit: Sept 12, 2016 19:19:00 GMT by colnerov
Sept 12, 2016 19:50:40 GMT
TBH thats what i would do . Take it to a hydraulic repair place . The fittings will be a couple of quid maybe and the pipe not much . I would not expect it to cost much really , it would only take someone less than 30 mins i guess .
gazz81
Sept 13, 2016 0:23:57 GMT
I do agree, although I'll still have the fun of trying to then connect to the 15mm household fitting on the tank!
Sept 13, 2016 5:07:22 GMT
Just get them to do the lot .
gazz81
Sept 13, 2016 10:43:58 GMT
Sorted!! Took the fitting out of the head and it turns out the part that threads into the head is 1/2"bsp (household compression fittings!) So I can just replace the whole lot for copper and connect to my tank via the 15mm copper pipe.
gazz81
Sept 13, 2016 14:06:25 GMT
