Apr 26, 2024 20:40:04 GMT
So, what I’ve been up to before work this week? I can’t really remember, so I’ll just use the few photos I’d taken, and explain those. The copper pipe I’ve used to plumb the brake servo vacuum pipe over to the inlet manifold was cleaned, lacquered and fitted I also fitted new posts for the bonnet pins As can be seen in the above photo, I have also tried to screw a fan switch into the radiator top tank. These are usually 22x1.5 thread, but it won’t go in. The pitch matches up, but when I measured the bung that I removed, it only measured 21mm. I’ve ordered a tap from China (I’m expecting great things) to re tap it. If it doesn’t work, I’ll weld a new boss on. I made some nylon bosses up on the lathe to space the coil pack up off the bulkhead. And drilled some holes I only drilled the 2 as the 3rd is in the drain trough, so it’s just a spacer. It’s nice and solid though. I removed the rear wheels, revealing my wheel spacers. Don’t panic, I’ve got prober spacers and new longer studs, but need to remove the half shafts to fit Rear calipers were fitted to make sure the handbrake cables cleared the rear coilovers. They do ( luckily as I hadn’t checked) Made some bracelets to mount the cables and tacked to the top link bars All welded and P clipped on Cables even clear the wheels too Some horses cam to see me when I was parked up in work The new fan feet mounts turned up Luckily they did fit upside down. The brackets that came with the radiator had the studs removed, drilled out, bent up and cut down And all fitted up And that was it, I was back on a day shift today as a colleague wanted to do my late shift. This has allowed me to drink wine.
Apr 27, 2024 17:14:19 GMT
No work this weekend, so after food shopping with Mrs Jonsey and a visit to some of her family, it was garage time. The half inch oil pipe and all the clips turned up so I fitted those. This took an unexpected bit of time, as once you’ve put the pipes on the barbs, they really don’t want to come off. One of the scavenge pipes has had to go above the crossmember but below the steering rack so I’ve slipped a bit of yellow PE gas pipe over it to stop it rubbing. That’s the oil circuit complete except for the breather circuit. Radiator next. If you remember from last week, the bottom hose run wants to go straight through the crank sensor. So I cut the stub nearly off and bent it up Then cut a wedge That’s not the actual wedge as after I’d taken the photo I realised the angle was wrong, so I cut another. This was welded to the radiator (badly) And a pic of the fan, rad and modified stub in place If I get a chance tomorrow I’ll try and connect the modified stub to the water pump inlet
Apr 28, 2024 15:14:27 GMT
BARN FIND EDITION, No work done on the Escort today. I decided to dig the Cortina out instead. I didn’t think there was much petrol in it so first off Jones Junior (the younger) and myself went to the petrol station in the Trafic to get a Jerry can full of 99RON. Whilst there I gave the van a jet wash as it was so green (we’re surrounded by trees), I could only see out of the screen where the wipers have been. When back home, the mower got a top up as it had run out of fuel last weekend (The Younger driving aimlessly round the field). As did The Younger’s quad, because he’d ran that dry last weekend too. But that would only idle and not take any throttle. Carb off, float bowl off, jets out, blown through, back together, sorted. It took a while to get fuel up to carbs on the Cortina as it always drains back. But once running, I drove it onto the field to see Mrs Jonsey, where it promptly ran out of fuel as in my excitement, and forgotten to add some 99RON. That sorted, The Younger and I went for a spin and thoroughly enjoyed. When back I decided to get the single seater out of the new garage and put it in the old. I wheeled it like a barrow as it doesn’t weigh much. I then cleaned that side of the garage bit Still need to sort all this too The Cortina now fits here I’ll finish with a pic of the Cortina being jump started off the mower as the battery didn’t have enough go in it to suck the fuel through for a second time.
Apr 29, 2024 10:34:34 GMT
As much as I enjoy the work on the Escort, it's great to see the Cortina in the sunshine
Apr 29, 2024 10:51:31 GMT
As much as I enjoy the work on the Escort, it's great to see the Cortina in the sunshine The Escort has taken over my life the last 2.5 years, so everything else has been neglected. It was good to get it out again, giving it a blast down some country roads. I would love to do a rack conversion, but that is for future me.
Apr 29, 2024 11:03:29 GMT
The rack conversion looks great from Retro Ford but it's not 2.5K great!
Apr 29, 2024 11:09:46 GMT
On call again, so another couple of hours done. I made a start on the bottom hose. I used to work developing vehicle heat exchangers and at some point I’d salvaged a couple of bent stub pipes off an aluminum brazed radiator. No before pic, but I welded them together at the angle I needed And fitted it between the bottom hose and water pump inlet. This isn’t finished yet as I have to add a stub for a heater pipe and the bypass hose from the inlet manifold, but I haven’t got the hoses yet to work out where I want them So I moved on to the throttle cable. I’m going to use the old cable but the throttle bodies don’t have anywhere to hold the cable outer. On the single seater, this was just a bracket on the chassis, so I needed a bracket. So I took the inlet manifold off Made this That bolts here And painted it black And then it was time to get some food in me before work.
v8ian
Apr 29, 2024 12:52:32 GMT
Apr 29, 2024 18:08:38 GMT
Thanks Ian. The bit onto the water pump on that hose what have been handy but I think the radiator end would try to occupy the same space as the crank sensor. The 90° silicon bend was only £13 and I had the straight hose left over from the top hose. I also needed to stop hemorrhaging money 😩
Call? Yep. A couple of hours in the garage? Of course. But it nearly wasn’t as it was raining, windy and cold so I did think about giving it a miss. None of you would have known. But I have to keep chipping away. The top quality Chinese m22 tap turned up It did the trick Anyone know of fan switch that kicks in around 80° or less? I bought a bypass hose from eBay. Can’t remember what car it’s from (could be Audi) but I just looked for a 24mm hose that had a bend in it so it misses the water pump (no pic) I welded a 24mm stub to the bottom hose bend All fitted I also refitted the alternator to make sure it clears and all’s good I cut the RS2000 throttle cable and machined the end to locate in the bracket I made earlier this week All fitted But the throttle flaps only opens 3/4, not fully. 😩 I’ll check the pedal ratio on the single seater tomorrow. An extension may be required.
Yesterday, I did nothing on the Escort. I went birthday shopping in the morning with The Younger, for Mrs Jonsey. Whilst out, the sun was in the sky! This mad me realise the AC in the Rav4 was not working. After shopping, I mowed the grass, and after went to my younger brother’s garage to regas the AC. Whilst there, he was mucking about making new front suspension for his Gilbern rally car so I stopped and gave him a hand. When I got home I had ham, egg and chips. It was spectacular as I’ve been on a diet for the last couple of months. Today I tackled the throttle pedal. This is a standard Escort item. I needed to extend the amount of pull to get full throttle at the bodies. This is a group 4 throttle pedal that are on rally cars It’s the best part of £70 by the time it’s in my hand. This is a group 4 throttle pedal in kit form I cut off the cable pull part of the pedal and extended it the same as the group 4 item. When fitted it gave me a pull of 4.5”. That seemed too much. So I pulled the throttle cable until the bodies were wide open throttle and I only needed 2” pull. So I shortened it until I had to 2” pull and welded the original cable end to the top. I then welded a strengthening rod to it . That gave me this Years ago whilst competing, it was very cold, so I was wearing my walking boots (not suitable,I know). I had an aluminum grip on the throttle pedal and whilst braking, I hit the brake and throttle at the same time. This launched me over a grass bank and into the air. So I took the grip off to continue the rest of the day. I wanted to refit the grip, but cut it down a bit The pedal was originally zinc coated so I should have painted it silver, but I’ve not got any. I didn’t want to paint it black so I primered it and then clear coated it And fitted I’ve now got full throttle. I had to drill a new hole for the cable above the old . And cable fitted I then started plumbing the fuel system ’m hoping to go to the Singleton Classic Car Show tomorrow but the weather might not be up to muster, so I may have to give it a miss
