It's a Triumph 2000 MK1 1969, the front and rear indicators work, but the door pillar and dash warning lights don't. I believe the non working dash lights are a MOT fail.
It has a 3 pin flasher unit, pin 1 is 12v supply, pin 2 is feed to the front and rear indicators and pin 3 is for the dash and pillar repeater lights.
Fitted a new flasher unit and the dash/pillar lights still don't work, if I provide pin 3 with 12v, they do work (but not flash!). This must mean that the flasher unit is bu**ered?
As far as I can see, the dash/pillar lights get 12v from the flasher unit? Or am I missing something?
Thanks
Andy
