I may be taking delivery of this 2.5 powered machine, it will be coming from Malta, I have some details but the rest such as cost, and any expenses etc... will be added asap, have a read, have a look!
Just trying to 'drum' up some interest
Ford Transit mk2, 1985 Di model (2.5 Direct Injection Diesel) SWB
The engine is in very good condition. Starts on the key. Recently had a new Lucas reconditioned diesel pump fitted, new water pump, new lift pump. filters , serviced regularly. Gearbox also in very good condition. Works great.
Body is in nice condition, does have that here and there defect as you would expect from a car of this age. Was repainted a few years ago, but is far from perfect. It is not finished to the show condition, it is also slightly matt due to the hot sunny days we have.
Interior of the van is also still very nice. Dash is clean. Seats were Re done about a year ago. All switches, lighting works as should.
Original steel wheels. Tyres are say 65% good for the rear ones, 95% at the front (two new front tyres where fitted not long ago).
Has a custom roof rack fitted. makes it look more retro, and can be very handy at some point. Unfortunately this will have to be taken off if sent overseas due to transport reasons. In that case, if the buyer still wishes to have it, I will need to cut in half to be put in the van and re joined once the buyer has it. This is a custom steel rack made out of mild steel angles, so can be easily welded back.
Internal back loading space was fitted with side wooden guards to avoid any objects hitting the side panels of the van. The floor was also given a false wooden level for any objects not to be directly on the van floor. Obviously the wood, especially the floor, is not at its best due to usage over time, a couple of stains etc...But this is nothing original to the van and can be easily removed or replaced.
Chassis is very nice and solid too. Just one corner at the back that needs some attention. its just above the back tyre.
It's also only a two owner van through its whole life!
