Been on the road for 2 months now after an 18 month long restoration, had a ton of time and money spent on it including
Engine removed, complete top end rebuild, new gaskets throughout (inc head)
New water pump, cam belt kit, clutch, radiator, dizzy, rotor, ht leads, plugs, temp sensors, valve seals, belts, steering rack (power steering)
Engine has had a re-bore not that long ago as it has +895 stamped in pistons. No play in piston rings or big ends.
Wiring loom cleaned and re-wrapped, engine bay cleaned, rust treated, zinc primered and painted
New wheel bearings all round
New discs and pads all round
Recently new rear calipers, all new rear brake lines, fresh fluid.
All new gearchange bushes
All new suspension bushes throughout, new bottom arms
New battery
New engine mounts (uprated G60)
Front subframe & rear axle powder coated black, front anti-roll bar blue
All brake calipers cleaned & caliper painted blue
New Bilstein shocks all round
40mm lowered springs
Borbet 15" alloys with new Uniroyal Rainsport 3 tyres
New sunroof seal
New Lancashire Green tint windscreen
Alpine cassette head unit with 6 disc changer in boot, Mac Audio uprated standard fit speakers
Central locking with Toad Thatcham Cat 1 alarm & paperwork
Manifold & downpipe de-rusted & high temp exhaust painted & new studs+ nuts
Underside steam cleaned and Tetrosealed
Big bumper bodykit all treated with Gtecniq C4
Stacks of history and paperwork
10 months MOT remaining
Agreed valuation with Adrian Flux of £4500 on classic policy
This is not a concourse car, but has been loving restored by me and my old man, there are some stone chips, little scuffs and 3 small rust scabs about 10mm wide on the back, it was done as a timewarp car not a show winner as I'm not that anal.
Only selling it as I've put so much time and money into it I'm scared to drive it anywhere, it's not getting the use it should, and I've got the chance of an E30 I've been after for some time.
It does have a few niggles- 1st to 2nd gearchange when cold at high revs will grind the synchro a little, but fine when its warm or you're gentle when its cold. (New gearbox oil too)
The odometer stopped sometime from the last MOT until now, although all the clocks work fine (backed up by old MOT's)
Central locking works fine on the key, but will bounce back when you lock it from the key fob, so it's only the actuator fighting a stiff mechanism, but I'm not stripping the door cards off to WD-40 it at this stage!
It's a cracking little car, everything is stiff and like brand new, pulls like a train and stops on a dime. If i had dry storage I'd throw a sheet over it and let it just go up in value, but I've got too many cars and I'm hell bent on this E30 so unfortunately she has to go. There are probably lots more new parts than i listed, I've just lost track!
New battery
New sunroof seal
