The car is a mk6 Celica imported from japan in 2005. It is a rare edition known as the st202 (or SS-ii) which means it was given a more powerful engine, the super strut suspension system and a much better manual gearbox. The car has been siting around for almost a year now but has been started and driven almost every weekend with regular checks etc. I bought this car to fix up as my first car, but i put too much money into getting work done on it, so by the time it came to insure it, there was no way i could afford it anymore. I need to free up some cash now, so this has to go.
Good Points:
It has full uk service history
it has the original paperwork folder with the original information booklet and other things included with the car when new with a translated version
It has 8 months M.O.T With two advisories which are a chip on the windscreen and a corroded exhaust
Brand new exedy clutch fitted in December (has done roughly 50 miles since then)
Very rare TRD side skirts + front and rear spats
Brand new front tyres fitted a month ago
rear tyres have roughly 5-6 mm of tread left on both
Brand new rear brake pads
Brand new air filter
Brand new oil filter (not fitted yet because i haven't had the time)
It has been derestricted from factory Japanese speed limits
Cat 1 alarm and immobilizer professionally fitted with certificate and original operation manual (a Hawk Ha 101 alarm)
Two full sets of keys (the actual manufacturer key, an alarm fob and an emergency override key for each set)
A flip up touch-screen dvd player which is worth £200 from new
Aftermarket steering wheel, boss, gear knob and rims
AC still works perfect (fully electric too which was an optional extra)
Just fitted a brand new battery (Fitted on 24/08/16)
Everything else works fine and as it should
Bad Points:
The indicators do not auto correct (most likely due to the boss)
It has done 147,000 miles
The cluster is from japan and therefore the mileage is in km (237,000)
The paintwork needs some tlc in places
The indicator and wiper stalks are the on the opposite side to English settings
There is a large dent on the left wing and a small dent on the right wing(as pictured)
It has a small tear in the front drivers seat bolster
It has been sorn'd for almost a year now
The trd kit has a few cracks/chips here and there
One of the alarm fobs will not work however it is not broken it just needs re-assigning
the rear plate has a playboy insignia in the actual plate (no way to remove)
Random marks in the boot (the plastics have scratches on them i think)
If you are properly insured to drive the car then by all means test drives are available,however i need proof that you at least have roughly enough cash on you or in your bank account (this is to help prevent "test pilots")
If i get the full asking price i will throw in a valet, oil change, oil filter change and normal rear plate.
Its a great car, i love it but i just really need some money for my first car now.
The price is £600 however I am open to close offers....
Viewings welcome weekends and weekdays
Good Points:
Bad Points:
