cr500dom said:
If you now have a Front mounted intercooler then you would be better off losing the bonnett scoop as it will reduce the effectiveness of the front mount
If you still have the intercooler under the scoop then you need a Lamp pod to really make it work ;D
Dom, the intercooler is behind the meshed bumper now, original bonnet scoop is blanked off, but may be opened up again if I fit an oil cooler.
