Jun 14, 2016 13:46:17 GMT
After some advice I'm in the middle of a engine conversion and the std engine driven pas pump is in the way lve had this problem in the past and I've got round it by using a electric pump from a saxo/106 but it only had two wire so pretty simple
now days the the saxo pumps are getting harder to find and let face it they stopped making the cars 15 years ago so there all old now so I've been looking into a newer version like VAG/ford/VX and it looks like most are the same as one another but they all have two or three multi plugs on them so how do you wire them up?
they still have the main feed wires IE the two big live/earth wires and my guess is the other wires are to control how heavy or light the power steering is to operate
so so my question is has anyone used this type of pump and if so can you just wire it up using the two big wires (like the saxo) and not use the rest or is it more difficult
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Jun 14, 2016 13:49:06 GMT
Photo of a typical pump
froggy
Jun 14, 2016 15:25:04 GMT
A class Merc has a simple pump set up iirc
Jun 14, 2016 15:39:09 GMT
Photo of a typical pump Do not touch that kind of pump, they need an ECU and an angle sensor to run them. Saxo pump is bullet proof and lasts forever anyways. In 10 years in the motor trade I haven't sold a single one. Stick with that.
Nissan Laurel SOLD BMW E34 Diesel SOLD Toyota Soarer 4.0 V8 SOLD Audi A4 1995 TDI SOLD Peugeot 205 1.9 TD SOLD Lexus IS300 SC
Jun 14, 2016 15:55:58 GMT
Last Edit: Jun 14, 2016 15:58:30 GMT by mgbizzle
Jun 14, 2016 17:16:09 GMT
Really? I've know loads of them fail. My mate at a local french car breakers used to get £20 each for them as old core, he collected them by the pallet load and sent them to Poland for refurb. They usually get noisy and seize up, or alternatively they lock up after being stood for a while.
The VAG pumps like that talk to an ECU and a steering angle sensor to set the pressure. If they're not happy with the input, they turn off completely.
You could probably bypass the electronics to feed 12v to the motor directly, but they draw an incredible amount of current when run flat out.
Yep, kill them loads of time, most of the ones out of crashed cars die fast because they don't like impacts either, try to get one out of a rear ended car if possible.
I'd guess the reason you haven't sold any is because nobody with a 106 or Saxo is buying a new pump that costs the same as the car...
you don't want the c2 one, thats directly on the rack.
Jun 15, 2016 13:05:31 GMT
A class Merc has a simple pump set up iirc Thanks for that I've just had a look a one and it looks pretty simple and it stands upright so that mite work better for my situation
Jun 15, 2016 13:10:10 GMT
Thanks for all the advice guys much appreciated If I can stick with the engine driven pump I will but if a cant then il look at the merc pump as it's probably a bit more reliable and newer
hario
S202 C300STD
Jun 16, 2016 12:22:02 GMT
Thanks for all the advice guys much appreciated If I can stick with the engine driven pump I will but if a cant then il look at the merc pump as it's probably a bit more reliable and newer I have the very same clearance issue and requirement for an epas pump so I've been doing loads of reading on and off over the past year, and my findings are: Get one from a Vauxhall. They are cheap and simple to wire. They aren't much bigger than the Saxo/106 ones so I can't comment on reliability, especially if you fit it to a heavier car, but basically they are the only ones you can wire easily. The kit car people use them a lot, so much that I managed to find a wiring diagram for one off a forum, I can't remember where I saved it but I'll dig it out if you remind me. Literally this: www.ebay.co.uk/itm/ASTRA-G-MK4-ELECTRIC-POWER-STEERING-PUMP-PAS-98-04-/110492822716?hash=item19b9e2acbc:m:mvMAQzFF4AIIP6OwAh9COXABeers.
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
hario
S202 C300STD
Jun 16, 2016 12:22:35 GMT
I didn't know about Mercedes A-Class ones though.. hmm
Electric power steering pumpsChasR
@chasr
Club Retro Rides Member 170
Jun 16, 2016 16:39:19 GMT
I've had a 106 and a few mates have had them too. So far no issues with any of them
Jun 19, 2016 14:52:05 GMT
I've plumbed up a couple of cars with A class merc pumps, they seem to be simple
hario
S202 C300STD
Jun 19, 2016 15:47:13 GMT
I've plumbed up a couple of cars with A class merc pumps, they seem to be simple What are the I/O's on them mate?
