Hi Guy's Looking for some wheels to fit a trailer. As a spare..... 13" 4×41/2 pcd 7/16" studs The wheels already fitted have 3 small mushrooms probably to hold on the hub cap. I'm really struggling to find a spare so I thought if I can identify the vehicle the wheels came from it might help. Any help would be gratefully accepted Thanks Truckster
Pid363!
Madness is all in the mind!
Trummy 2000? Marna van heavy weight or what ever they called it RWD toyota starlet. Mgb and a60 would fit but there 14's hope that helps
Stupid is as stupid does!
Could be standard old type caravan wheel.
joe90
Yorkshire and The Humber
Jun 11, 2016 21:02:46 GMT
4x4.5 inch stud pattern is reliant scimitar, some triumphs and most Japanese stuff.
Bryan
Jun 11, 2016 21:30:58 GMT
It's any old caravan wheel from a b&b chassis made between 1960 and 1982 you can find the odd one on ebay under classic or vintage caravan wheel I sell them all the time for £50 a pop don't have any at the moment might have a couple next week If you look on the hitch it says either peak or b&b therethe same pcd same period caravan trailers
Caravans are cool
Jun 14, 2016 14:11:54 GMT
Thanks for the information guys but I'm struggling with the offset most being around 40mm. I've got a offset of 25mm and a 5mm gap to play with. "Should have made the dammed trailer my self" Once again thanks for the information I'm going to have a rethink as I might have to replace the suspension units to gain a more modern pcd set up. Truckster
andyborris
Jun 15, 2016 20:14:02 GMT
They sound like TR3 or 4 wheels, are they 15 inch?
Last Edit: Jun 15, 2016 20:14:24 GMT by andyborris
Jun 15, 2016 22:24:50 GMT
No andy orris 13inch also on a more detailed inspection the centre is riveted to the rim. The plot thicknes.....
Jun 16, 2016 20:37:49 GMT
Could be Austin A30 wheels if there that stud pattern and reverted.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
gazz81
Jun 16, 2016 23:15:43 GMT
Jun 17, 2016 23:43:23 GMT
As they say a picture speaks a thousand words
