May 27, 2016 21:06:13 GMT
a workmate is looking to be making a rs200 kit car in the near future but we're both stuck for ideas for the gearbox.
basically the idea is to be using a sierra cosworth engine turned round so as to fit in the back with the box facing forward, but being as he wants it to be 4 wheel drive as well if he uses the sierra 4x4 box (mt75) then with it giving a 60/40 torque split as standard then in the kit it will be giving 60% to the front,is this adjustable or has anyone any ideas on a better or more sutible box to use?
of course he could go get a proper rs200 box but they are around 15-20k, a little expensive.....
craig
May 27, 2016 21:31:28 GMT
Porsche 911 AWD box ? Not cheap but still a lot less than a proper RS200 item.
froggy
Cradeley motor works used to do a kit that put the engine in the front to use a std ford 4x4 layout .
93fxdl
Enter your message here...
May 28, 2016 16:42:30 GMT
Use an "ordinary" 4x4 box from something lik a landy, with the diffs inverted to reverse the drive direction. Ttfn Glenn
May 30, 2016 10:35:10 GMT
Audi Quattro ?
May 30, 2016 16:33:45 GMT
If you are having the engine in the rear the 60/40 will be 60 to the rear not front
May 30, 2016 16:36:03 GMT
But you could always use anything with an electronic centre diff to help split it. Bue due to the design of a conventional 4wd box, the split can never be less than 50% to the wheels closest to the gearbox
May 30, 2016 19:57:48 GMT
If you are having the engine in the rear the 60/40 will be 60 to the rear not front really? this would make it easier as we could use the sierra box. but our understanding is in a sierra the torque split is 60/40 toward the rear, hence when the engine and box is turned round for the rs200 then the split would be the other way round? ('rear prop from the sierra now driving the front) we've anticipated flipping the diffs thinking the engines turning the other way when installed
May 30, 2016 20:21:36 GMT
The split Is 60 to the front In a sierra, so it would be 60 to the rear in the kit car. Yeah, flip the diff or run the engine backwards to go forward :L
rs200 ideas/suggestionsstealthstylz
@stealthstylz
Club Retro Rides Member 174
May 30, 2016 23:16:01 GMT
Sierra is biased to the rear, something like 33-67% front - rear iirc
May 30, 2016 23:34:01 GMT
![](http://img.photobucket.com/albums/v11/ettore_bugatti/banner.jpg) Click picture for more
May 31, 2016 11:12:26 GMT
A bit left field but what about a VW T3/Vanagon Syncro gearbox? If you're not dead set on using the cossie engine you can get bellhousings for them to use Audi and Porsche engines (e.g. 944 lumps) and Subaru engines too.
Last Edit: May 31, 2016 11:21:46 GMT by lufbramatt
alecf
May 31, 2016 11:47:16 GMT
contact raceway engineering for a reverse ratio transfer box. They are used loads in the comp safari world.
alecf
May 31, 2016 20:55:09 GMT
I meant to put rakeway not raceway
A bit left field but what about a VW T3/Vanagon Syncro gearbox? If you're not dead set on using the cossie engine you can get bellhousings for them to use Audi and Porsche engines (e.g. 944 lumps) and Subaru engines too. VW T3 boxes are no where near man enough for the sort of power you'd want in a RS200 rep, they struggle with NA scooby engines or TDi engines attached, and have pretty short gearing too
yeah thought it might be a silly idea- was just based on the proposed layout, couldn't think of much else rear engine and 4wd apart from Porsches! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
I'd say stick with the Cosworth 4x4 MT75 box and concentrate on how to alter front rear split. I'm sure there must be specialist who can reconfigure the viscous coupling
