My 1983 Porsche 924 na for sale as losing/lost storage for it. Was using it as a daily 78k on the clock, loads of new wiring as these are common to wiring faults.
All replaced with correct spec wiring. Starter wiring, earth straps, lives, etc
Electric Windows still work but the passenger will need a new pin or switch as on removing the doorcard the switch fell apart! The passenger doorcard is warped due to water getting in through the mirror but this has now been fixed.
Battery tray has been played. Only other rust is a small one by the jacking point on the drivers side but I will try get this sorted before it sells.
Car came to me very lumpy and bad on fuel but this was due to an air leak after the throttle plate and was corrected by adding loads of fuel, I have sorted this and corrected the mixture, it needs a very slight fiddle still but needs to be done with a c02 probe which I don't have runs and pulls fine tho ?
New bulbs, starter, voltage regulator, plugs, leads, coil, dizzy retimed to factory settings, alternator regulator upgraded to 14.4v and belt done
Comes with oil, oil filter, fuel filter ready for a service, I haven't had chance to do it but it all comes with car.
The handbrake does not work, I assume it needs shoes or cables as it will catch high up and the brakes work, either aren't very expensive. There is slop in the gearstick and iv checked, it's the pin on the lever itself these are available on an exchange basis ?
I have removed the head unit and speakers out the front as they were knackered and it's a nice car to just cruise around in. I will throw in some speakers for you to use though as I know some people won't like this.
Seats are MINT no tears nothing, very very comfy also! Dash has normal cracking, new alcantara gear gaitor, have recently dyed the carpet black to bring it up to date. Have removed all un needed wiring to simplify the interior.
5 good wheels with tyres and full porsche tool kit!
Bodywork was terrible when I bought it (just old paint) I have since flatted everything out and made everything flat bar the corner of the bonnet and the drivers wing needs some more filler. I then sealed it all in roughly, run as is or get it painted your call!
Moted until August this year.
Taxed until end of this month which I will leave for new buyer.
Drive away!!
Could be a very cool summer car with not a lot of money spent on it!
Have a steering boss, coilovers and wheels for it if the buyer is interested!
Please read everything before asking questions, open to swaps/p/ex on anything cool or diesel ?
Cash on collection from Kingston upon Thames, i can however bring it to herefordshire but this would need organising before hand with me.
Appreciating classic, and cheap chance to own a Porsche!
£1500 ono
Cant work out how to add pics on here so heres the ebay ad, can you post pics on here without flickr etc?:
www.ebay.co.uk/itm/291773109361?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Drive away!!
£1500 ono
