Got 5 of these babies up for grabs. Usually only get 4!
These are a complete set with barrels, inserts, caps and bolts. There is also 4 Mohawk() 235/45/R17 tyres to go with these with at least 5mm tread on each.
All you need to do is get these blasted and then coated, sprayed or polished which would cost you pennies to do and voila... a set of wheels which I've seen going for at least £1k on the bay of bidding and will look super sweet on your ride...
Was planning to fit these to my VW mk1 cab, but the 17" diameter made it look like a 4x4. Also tried them on my e91 and my MK3 Caddy and they looked mega PENG! but the misses said I can only do up one ride...
Therefore I am selling these to fund some 16" 4x100 fitment OZ Superturismos, Compomotive MO5 Flat Faces or Avez A's.
£400
£400
