A big box filled with 307 shiny new Toyota parts arrived from the UAE. I firmly believe in only using genuine Toyota parts (with the exception of suspension, brakes and possibly engine internals in this particular build..), after all, I'm buying a Toyota for its build quality and reliability, and if it starts to get taken over by Chinese toot, well it's not a Toyota any more. All the parts are made in Japan (with the exception of oil filters and spark plugs), which is more than can be said for many modern Toyotas.
I spend hours going through the technical part diagrams and identifying every part which needs replacing. Surprisingly, 95%+ of the components are still available, and it's time well spent when it comes to reassembling everything, no missing bolts or O rings. Or that's the plan.
Many parts of this order were new bolts which were either badly rusted, missing or replaced with non-standard ones and rubber bushes which had split or hardened. More major items include both lower trailing arms, a full engine gasket set, oil filters, air and fuel filter, HT lead set, idle speed control valve, handbrake cable, distributor cap, front wheel bearings, AC accumulator and more. I've added the list in case anyone is interested!
GASKET KIT, ENGINE OVERHAUL 04111-75100 1 12762
SHAFT, BALANCESHAFT DRIVE GEAR 13636-75010 1 362
SPACER, BALANCESHAFT THRUST 13635-75010 1 146
FILTER SUB-ASSY, OIL 90915-20001 3 1101
HOSE, RADIATOR, NO.2 16572-75090 1 1460
THERMOSTAT 90916-03101 1 1459
BELT, V(FOR FAN & ALTERNATOR) 5PK890 1 411
ELEMENT SUB-ASSY, AIR CLEANER FILTER 17801-08010 1 3015
CORD SET, COIL & SPARK, W/RESISTIVE 19037-75010 1 3825
PLUG, SPARK K16RU 4 193
RING, O, DISTRIBUTOR HOUSING 90099-14127 1 176
PACKING, DUST PROOF 19127-15120 1 161
HOLDER ASSY, ALTERNATOR BRUSH 27370-35060 1 1010
FILTER, FUEL(FOR EFI) 23300-79446 1 4548
BLADE ASSY, REAR WIPER 85242-35010 1 1256
GASKET, EXHAUST PIPE 90917-06057 2 303
BOLT, EXHAUST PIPE 90105-10388 4 55
NUT, REAR WIPER ARM ASSY 90179-06158 1 57
CAP SUB-ASSY, DISTRIBUTOR 19101-75010 1 4911
COVER, CONNECTOR(FOR BATTERY TERMINAL) 82821-35020 1 597
CLIP 90467-10018 2 64
INLET, WATER 16321-0W010 1 1517
GASKET, THERMOSTAT GUIDE 16119-75020 1 191
GASKET, EXHAUST GAS TEMPERATURE SENSOR 90430-08252 1 57
BOLT, EXHAUST GAS TEMPERATURE SENSOR 91651-60616 2 57
GASKET, THROTTLE BODY COVER 22215-75050 1 191
FILTER, FUEL PUMP 23217-46090 1 468
PLUNGER, MAGNET SWITCH 28235-55050 1 1328
STARTER KIT, MOTOR TERMINAL 28226-74070 1 659
STARTER KIT, BATTERY TERMINAL 28226-64200 1 470
BEARING (FOR INPUT SHAFT) 90363-12002 2 369
CLIP, RADIATOR HOSE, NO.2 90467-37002 2 248
PIN, W/HOLE(FOR FRONT DISC BRAKE ANTI-RATTLE) 90240-06014 4 100
RING, O(FOR OIL PUMP) 15188-75020 1 301
VALVE, OIL PUMP RELIEF 15131-24010 1 255
BRACKET SUB-ASSY, CATALYTIC CONVERTER, REAR 17503-62050 1 1304
*** STD. PART 90561-10018 4 93
RING, O (FOR SPEEDOMETER SENSOR) 96711-24030 1 142
GASKET, PRESSURE PORT, NO.1 44327-26020 1 136
RING, O(FOR STARTER YOKE) 90099-14064 2 269
WASHER, WAVE(FOR CAMSHAFT SUB GEAR) 90206-42001 1 57
RING, O(FOR OIL LEVEL GAGE GUIDE) 96721-19010 1 100
RING, O(FOR FUEL INJECTOR) 90301-07001 5 157
HOSE, VENTILATION, NO.2 12262-75050 1 573
Dipstick guide bracket bolt 91641-C0814 3 44
HT lead clamp 2 90469-05006 1 77
Number plate clamp 90179-06127 2 41
BOLT(FOR CYLINDER HEAD COVER) 91513-J0628 6 36
WASHER, SEAL(FOR CYLINDER HEAD COVER) 90210-07001 6 113
Bell housing bolt 91611-61020 2 66
Bell housing bolt 91612-61050 2 74
Bell housing nut 94130-61000 2 47
GASKET(FOR MANUAL TRANSMISSION FILLER PLUG) 90430-18008 4 50
SEAL, OIL (FOR TRANSFER CASE) NO.1 90311-15008 1 293
SEAL, OIL(FOR TRANSFER ADAPTER) 90311-40007 1 540
SEAL, OIL (FOR REAR DIFFERENTIAL CARRIER) 90311-38047 1 399
BOLT, NO.1 (FOR REAR DIFFERENTIAL CARRIER SET) L42 90116-08233 1 61
CUP KIT, REAR WHEEL CYLINDER 04906-35130 1 825
Handbrake bellcrank bolt 90143-60002 2 66
PIN(FOR PARKING BRAKE BELL CRANK) 90249-08068 2 192
PLUG, HOLE(FOR REAR BRAKE) 47491-20011 1 129
BUSH, FRONT STABILIZER BAR, NO.1 48815-35100 2 457
LINK ASSY, FRONT STABILIZER 48820-35030 1 4451
Front stabilizer bar drop link top nut 94184-01041 6 44
RETAINER, CUSHION, NO.1(FOR FRONT STABILIZER BAR) 90948-02131 8 230
CUSHION, FRONT STABILIZER 90948-01003 6 100
Stabilizer link nut 90179-12141 3 61
NUT(FOR FRONT SUPPORT TO FRONT SHOCK ABSORBER) 94184-01241 2 55
CUSHION, REAR SHOCK ABSORBER, NO.2 90948-01045 2 230
RETAINER, CUSHION, NO.1(FOR REAR SHOCK ABSORBER) 90948-02119 2 227
BUSH, REAR SHOCK ABSORBER 90385-19007 4 102
WASHER, REAR SHOCK ABSORBER CUSHION, NO.1 90948-03020 2 241
BUMPER SUB-ASSY, REAR SPRING 48306-35180 2 3127
Bump stop bolt 90119-08A30 17 47
COVER, REAR STABILIZER BRACKET 48823-35060 2 426
BUSH, STABILIZER(FOR REAR) 48815-10090 2 515
LINK ASSY, REAR STABILIZER 48830-35020 2 3632
Rear stabilizer link top nut 94183-00831 2 36
RETAINER, CUSHION, NO.2(FOR STABILIZER REAR BAR) 90948-02127 2 176
PLUG, BLEEDER(FOR DRUM BRAKE, REAR) 47547-12010 2 150
INSULATOR, ENGINE MOUNTING, FRONT 12361-35090 2 3436
Radiator bolt 91621-J0814 1 36
Exhaust manifold heatshield nut 90179-06257 2 44
VALVE ASSY, IDLE SPEED CONTROL(FOR THLOTTLE BODY) 22270-75040 1 17711
CLIP(FOR FUEL PUMP FILTER) 23229-16010 1 49
Spare wheel winch bolts 91651-60818 4 66
GASKET, FUEL SUCTION TUBE SET 77169-60010 1 566
Fuel filler pipe bolt 91626-B0822 1 57
Fuel pipe bracket nut 90179-06161 2 44
HOSE, WATER BY-PASS 16261-75040 1 255
ISCV screw 90079-11001 2 41
GASKET(FOR FUEL HOSE) 90430-12026 2 50
GASKET, CLUTCH MASTER CYLINDER 31415-10010 1 74
TUBE, FRONT BRAKE, NO.9 47315-35320 1 379
TUBE, FRONT BRAKE, NO.2 47313-3D050 1 379
TUBE, FRONT BRAKE, NO.6 47316-35250 1 379
TUBE, FRONT BRAKE, NO.4 47314-35330 1 379
Clutch master cylinder nut 90179-08038 2 48
Battery clamp front bolt 90119-08974 1 47
JOINT ASSY, FRONT UPPER BALL 43310-39016 2 3959
CABLE ASSY, PARKING BRAKE, NO.1 46410-35770 1 4262
BUSH(FOR PARKING BRAKE EQUALIZER) 90385-12012 2 66
Handbrake equalizer bolt 90109-08244 1 68
DEFLECTOR, DUST (FOR REAR DIFFERENTIAL) 41252-35040 1 580
NUT (FOR REAR DRIVE PINION) 90179-20018 1 150
Front suspension support nut 90179-10212 6 49
GASKET, MAGNET SWITCH COVER 28175-55050 1 90
ABS wire bolt 91626-G0616 3 41
CAM SUB-ASSY, FRONT SUSPENSION TOE ADJUST 48409-35050 4 680
Upper wishbone bolt 90105-14105 1 506
Upper wishbone bolt nut 90179-14062 1 68
RING, SNAP (FOR REAR AXLE SHAFT) 90520-36045 2 91
RING, SHAFT SNAP (FOR FRONT DRIVE INNER SHAFT OUTER) 90521-29002 2 50
COVER, DUST(FOR FRONT DRIVE SHAFT) 41336-35020 2 309
CLAMP, NO.2 (FOR FRONT AXLE INBOARD JOINT BOOT SETTING) 90949-01222 2 404
BEARING (FOR FRONT AXLE HUB INNER) 90369-54001 2 4851
RING, HOLE SNAP (FOR FRONT AXLE HUB) 90521-99114 2 301
PIN, W/HOLE(FOR PARKING BRAKE CABLE) 90240-08059 2 139
GASKET, BRAKE MASTER CYLINDER 47275-12020 1 57
Front strut bolt 90105-14104 2 208
Front strut nut 90170-14026 2 55
Belly guard bolt 90119-08A33 9 44
Fuel tank bolt 90119-08667 6 61
CYLINDER KIT, BRAKE MASTER 04493-30232 1 6074
CLIP(FOR FRONT FENDER APRON SEAL) 90467-10186 2 81
TANK, RECEIVER AIR CONDITIONER 88471-34010 1 2962
GASKET KIT, OVERHAUL 88335-2B030 1 1864
ARM ASSY, LOWER CONTROL 48720-35030 2 9362
Upper control arm bolts 90105-12287 4 171
Upper control arm washers 94622-31200 6 68
Upper control arm nut 90170-12039 6 57
Panhard rod bolt 90105-12288 2 161
Horn connector 90980-10619 1 180
Oil pump screw 93220-16014 4 39
Fuel tank stack bolt 90159-50219 13 36
SPACER, FRONT WHEEL INNER BEARING 43524-35010 2 927
Dashboard lower panel screw 93560-55016 1 40
