aij29
May 11, 2016 19:15:49 GMT
Hi Guys
I`m in need of a set of 165/55/14 tyres for a project but they seem really rare the only ones i can find are Nankang and Hifly neither of which i can get from any local Tyre fitters,
Does anyone know of any other brands that do this size?
Cheers Adrian
May 11, 2016 19:27:29 GMT
Is 165/60 not do able? Loads of choice for them.
93fxdl
Enter your message here...
May 11, 2016 19:56:31 GMT
I`m in need of a set of 165/55/14 tyres... I often try different size of tyres, something near but not exactly what you asked for might be fine. Any reason why you specifically need that size?
aij29
May 12, 2016 18:29:24 GMT
I`m in need of a set of 165/55/14 tyres... I often try different size of tyres, something near but not exactly what you asked for might be fine. Any reason why you specifically need that size? Hi I`m fitting 14x6 wheels to my car which runs 155/65/13`s at the moment and 165/55/14 gives the closest rolling diameter to them with enough width for the 6j rim without stretch, Its a really popular tyre size in Japan and is used on Kei cars running 14" wheels Cheers Adrian
Dez
Club RR Member Number: 34
165/55/14 Tyres?Dez
@dez
Club Retro Rides Member 34
May 12, 2016 19:44:05 GMT
You're talking 8mm difference overall between a 165/55 and a 165/60. 4mm on the rolling radius. Possibly less between varying brands. For the hassle findig 165/55 as opposed to 165/60 which are VERY common even as part worn as they stock ford KA fitment, I'd just go with the latter. Here's a pic of 165/60 on a 14x6 rim. ![](http://img.photobucket.com/albums/v617/dezaster/115/file_zpshmemrljr.jpg)
aij29
You're talking 8mm difference overall between a 165/55 and a 165/60. 4mm on the rolling radius. Possibly less between varying brands. For the hassle findig 165/55 as opposed to 165/60 which are VERY common even as part worn as they stock ford KA fitment, I'd just go with the latter. Here's a pic of 165/60 on a 14x6 rim. ![](http://img.photobucket.com/albums/v617/dezaster/115/file_zpshmemrljr.jpg) Hi Dez Thanks for the reply, They don`t look as tall as i thought they would, 165/60/14`s are 22mm bigger than the stock tyres would that make much difference to the speedo reading etc? Cheers Adrian
May 13, 2016 10:15:01 GMT
would that make much difference to the speedo reading etc? I find this site quite useful www.willtheyfit.com/
May 14, 2016 18:56:31 GMT
You're welcome
