Despite the fact I have electrical faults throughout the cortina I have decided to make an exhaust because when it does run it's rather loud!
Problem is I've never made one before - I have done a bit of research into what components I'll need but I cold do with some more advice
Joints - I wasn't going to use flexible ones but wasn't sure whether to us V bands as much as I need to, the manifold is 1.5 at the end with a 60s style v band which i was going to remove and fit a 1.5 to 1.75 reducer - upping it to the right size from the manifold out then using a sleeve to go over that for the main straight and secure with a U bolt
www.ebay.co.uk/itm/1-75-V-Band-Turbo-Clamp-CNC-Stainless-Steel-SS304-Flange-Kit-/221915051830?hash=item33ab2af736:g:PdUAAOSwVL1WCP29
Hangers - modern rubber types, shouldn't be an issue
Over axle - Jetex off the shelf affair
www.ebay.co.uk/itm/Jetex-Universal-Exhaust-Over-Axle-Bend-1-75-Stainless-Steel-/290617282192?hash=item43aa23ce90:g:pdIAAOSwNphWXfjc
Silencer - I want the cortina to have a nice raspy noise but nothing too loud so I have a few ideas
www.ebay.co.uk/itm/UNIVERSAL-STAINLESS-STEEL-EXHAUST-SILENCER-1-75-BORE-8-x-5-SECTION-x-12-LONG-/370539204477?hash=item5645db8f7d:m:mKGWMzGSgNI_dvNIEwp0T5w
this will need a tail pipe fabricating but would give the quietness I'm after.
www.ebay.co.uk/itm/Universal-Stainless-Steel-Exhaust-Bomb-Silencer-Tail-Pipe-Back-Box-/271524704833?var=&hash=item3f38223241:m:mj__24FKMu5rM4r0WL045oA
I'm not sure how this would sound but its straight through which is good for performance, I have a feeling that I'll need to cut the tailpipe and add a small bend in so that it exits the rear straight but thats just a personal thing!
