I'm running 17x7.5j ET35 fronts (15mm spacer)
17x8.5j ET35 rears
Wheels aren't really my thing (knowledge wise)
I basically want them both to look deeper/more dishy.
I placed the rears on the fronts with the 15mm spacer and they clear everything, it's close but they clear. Ideally I'd like to just have to buy 2 rear wheels (swapping the current tears to the front) but I'll buy 4 new ones is need be. I understand the measurements and ET but I don't know what ET is measured in (guessing MM.?)
I've got 25/30mm left in space to the arches from the current edge of the wheels (could push a little further and roll arches if need be)
A lower positive ET would create a deeper looking wheel whilst pushing the wheels out but I'm not sure which ET to go to as I'm unsure what ET is measured in. Any help would be appreciated.
17x8.5j ET35 rears
