bigdaz
Apr 23, 2016 18:01:34 GMT
Ok when I start my car the battery light stays on and the alternator dose not charge till the engine is revved is this normal ? And with no load and idle I'm only getting 13.3v ? And I'm only getting 5v at the plus side of the coil when the engines running I thought it should drop to 9v ? Are all these things related ? It's s 2.8 Granada
Rich
Club RR Member Number: 160
Ignition/charging system Granada Rich
@foxmcintyre
Club Retro Rides Member 160
Apr 23, 2016 18:44:05 GMT
Charge system sounds fine. Alternator is just getting a little old and lazy but charge rate is fine. Nothing untoward there. Is the car running ok or are you having ignition issues?
bortaf
Apr 24, 2016 14:25:05 GMT
5V at the coil aint right but the light not goin out is normal for an old alt, some go out at idle some don't, in 3 alts over the years on my P100 2 went out straight away 1 didn't, all worked fine (untill they didn't lol).
R.I.P photobucket
bigdaz
Apr 24, 2016 14:36:50 GMT
It seams to be running ok, what would cause it to only get 5v ?
bigdaz
Apr 24, 2016 17:15:28 GMT
Ok I'll go to speck savers tomorrow I was checking the wrong side of the coil, when I checked the + side when running I got 7.6v which is about right sorry :-(
