Vauxhall omega 2.2cdMercdan68
@forddan68
Club Retro Rides Member 68
Apr 20, 2016 19:38:09 GMT
First of all I know this isn't really retro , but hey it's a luxury old barge! A good mate spotted this down in Southampton at salvage market and called me saying he knew I liked old s&&t! And would I like it? 3 owners and 90,000 on the clock we won it at auction for £130.... So my mate Andy trailered it to my place and over the weekend I set about cleaning it up and assessing what I'd bought, the old girl is very very clean and tidy no rust no damage the only things needed are a new glove box which has been forced open and the radiator has a leak, Great interior and unkerbed wheels are a plus too Well chuffed with it I've never owned a Vauxhall before quite impressed with the build quality Going to use it whilst my E300 gets a makeover, again sorry for the unretroness but they seem To be rare in nice condition so thought I'd share it here !
Last Edit: Apr 20, 2016 19:55:25 GMT by Mercdan68
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
@forddan68
Apr 20, 2016 19:38:55 GMT
Apr 20, 2016 22:08:18 GMT
I love these, my dad had a white pre-face a good 15 years ago now. Was only a 2.0 but was reliable as anything else around at the time, clocked 70k in 3 years only needing a clutch and water pump. Very fond memories, especially of the comfort. Top buy!
Over the last 5 years ive had a few omegas and i love them there comfy i also prefer the dash in the facelift , my pal also has a mv6 , yours looks really clean, any plans for it ?
92 ford sierra 2.9 glsi ex police 87 ford sierra cosworth 3dr (In storage) scared to use 01 vw bora 2.0 sport 95 bmw 728i 92 2.9 xr4x4 barn find 87 xr3i 92 xr2i 89 escort van with rst (Blown up engine) 94 TRANSIT beavertail needs engine 3.0d waiting
@forddan68
Apr 23, 2016 12:25:11 GMT
Plans are just clean and use it!, although my boy has looked at lowering springs and wheels for it!! So maybe watch this space, like the idea of polished omega elite wheels and low
Last Edit: Apr 23, 2016 12:27:24 GMT by Mercdan68
@forddan68
Apr 27, 2016 20:01:31 GMT
Got a few jobs done on this,fitted a new handbrake gaiter,a new roof aerial as this as missing,cleaned the interior up a bit more,plugged in the computer and extinguished the engine management light,showed no faults so will see if it returns when I start using it,new rad arrived today along with a set of plugs,new number plates ordered , just need to pick up oil and filter,then find time to get this little lot done!
Apr 27, 2016 21:05:51 GMT
I know these are great value, but only £130 for one as tidy as this is truly unbelievable!! I reckon your George has got a point on lowering it though, they do sit a bit high as standard. I like the current wheels, a bit of a drop and a clean up and this will be a very nice example. Excellent purchase, get some more pics up.
@forddan68
This old thing is fighting me all the way! , Replaced the leaky rad done various other small jobs then take it for a run near my house and it throws a wobbly! Gearbox only in 3rd and a misfire at idle Take off throttle body clean replace plugs check water oil etc, all fine runs great then gets up to temperature and the gearbox plays up again, gonna go around to my mates and plug it in and see what faults come up I suspect a camshaft sensor? Still well impressed with the old bus she Cleans up lovely and that interior is very comfy!
@forddan68
omegod
Sounds like a cam sensor DO NOT USE A PATTERN ONE as they are wibblepoo , GM only
@forddan68
Sounds like a cam sensor DO NOT USE A PATTERN ONE as they are wibblepoo , GM only Cheers take it its main dealer then, looking at a few on eBay , interpart though
@forddan68
May 13, 2016 20:37:18 GMT
I didn't take the advice and thought I'd try an eBay buy pattern part sensor Bad idea car runs even rougher and won't idle, I've stripped it out again and have a GM part arriving to fit Another lesson learned! At the tender age of 47 I should of learned by now! But at least my son has learnt another job, we stripped it back out in about 5 minutes last night
@forddan68
May 23, 2016 20:09:44 GMT
GM cam sensor fitted,problem still persists,plugged In again today by my good mate Andy, we're sure it's the Coilpack so I've bit the bullet and bought a new one,will see when that arrives,this car is a challenge! Too modern to many electrical gubbins
Phil H
Club RR Member Number: 133
Vauxhall omega 2.2cdPhil H
@philhoward
Club Retro Rides Member 133
May 23, 2016 20:13:44 GMT
Did you actually get the fault codes read?...
@forddan68
May 23, 2016 20:24:57 GMT
Did you actually get the fault codes read?... Yes mate we read the codes and one code seems to point to the Coilpack p1781?
Last Edit: May 23, 2016 20:27:11 GMT by Mercdan68
Rich
Club RR Member Number: 160
Vauxhall omega 2.2cdRich
@foxmcintyre
Club Retro Rides Member 160
May 23, 2016 21:27:26 GMT
P1781 is engine torque signal circuit apparently. Coil codes are usually but not limited to p03xx codes.
@forddan68
P1781 is engine torque signal circuit apparently. Coil codes are usually but not limited to p03xx codes. Thanks rich, seems according to our investigations many fault codes can be thrown up by coil packs, so will see if the new one sorts the problem ......
@forddan68
This car has given me the right hump! Brand new coil pack and a new gm cam sensor and new crank sensor ,all to no avail now found out it's the ECU,was told by the experts these don't fail,mine has and at £100 I just can't be bothered it's sat on the drive looking sorry for itself,the first £200 buys it with mot until October,and a surberb body, no rust or dents!............
