I apologise in advance if this is in the wrong section as it relates to a modern car, but here goes.
Car is a 2007 VW touran.
The socket disintegrated as a result of water ingress so I am trying to fit another. I just need to know which cable connects to which number pin on the 13 pin plug but an internet search has been fruitless, most of the diagrams I have found don't tie up with the cable colours I have on the car, so I wondered if anyone had access to a workshop manual or similar.
I have the following (Cable colour/trace):
back/green
black/white
grey/black
grey/red
grey/white
red/purple - this appears to be a switched live.
blue/red
Heavier duty:
red/green - this appears to be a permanenet live
brown - Earth
brown - Earth (theres two)
I have tried switching on the ignition and each circuit in turn in order to obtain readings on a multimeter off each wire, but apart from what I've listed above the search was fruitless.
Thanks in advance!!
David
back/green
black/white
grey/black
grey/red
grey/white
blue/red
Heavier duty:
brown - Earth
Thanks in advance!!
David
