Apr 13, 2016 16:05:35 GMT
Hello,
trying to work out what camshaft is in my 1600 pinto.
markings on the end of the cam shaft is HH z10632 and it's engraved with s2
inbetween lobes 1 and 2 is K355-c
anyone know the cam?
the ports looked a bit oval, but from what i can tell everything else standard. it has a 34 inch carb on it.
Thanks
Apr 13, 2016 17:05:54 GMT
I bet that runs a bit rich with a 34 inch carb doesnt it ?
Apr 13, 2016 21:25:43 GMT
I would guess at it being standard not many people bothered tuning the 1600 it was always easier to drop in a 2 litre. What's it going into?
There's plenty of info on porting the pinto head on the net and there's also the book on pinto tuning that has everything you ever need to know and more
Last Edit: Apr 13, 2016 21:27:29 GMT by dodgerover
gazz81
Apr 13, 2016 21:37:11 GMT
I would guess at it being standard not many people bothered tuning the 1600 it was always easier to drop in a 2 litre. What's it going into? There's plenty of info on porting the pinto head on the net and there's also the book on pinto tuning that has everything you ever need to know and more I have said book in pdf format.
Apr 14, 2016 11:17:48 GMT
I was just curious to what cam as the engine was removed from a capri and was going up for sale, just i never seen that cam and theres no ford markings.
the 34 inch i thought they came with the 1600 pinto but from the transit? i do have a lovely vv carb aswell haha
Apr 14, 2016 11:32:33 GMT
34 ICH I think not inch, transits have a teeny tiny little webber or vv carb
Apr 14, 2016 12:42:27 GMT
sorry i meant ich haha other wise that would be a monster of a carb! shame there's not a lot of want for the 1600's as prices are around £40
bortaf
Apr 15, 2016 12:54:46 GMT
Standard cams arn't allways marked ford, some have the oval cast into them most have made in USA cast into them, how many (if any) dimples are cast into it 1 or 2 ? any colour on it ? K355-c is the usuall casting mark for a standard cam but it could have been reground? if it was it will be marked on the rear end face (faces the bulkhead)
R.I.P photobucket
Apr 15, 2016 14:26:57 GMT
There wasn't any ovals and no dimples. There was two circles stamped 1 and 2 inside them. The end face had engraved S2 HH z10632
Apr 15, 2016 14:50:17 GMT
Apr 15, 2016 16:13:18 GMT
Google www.locostbuilders.co.uk/viewthread.php?tid=106696They seem to think its a Kent Cams race jobby , but do not provide any evidence . They quote a gp1 cam but i cannot see any correlation between that spec and the number you have on yours ? Maybe worth giving them a email as it maybe true . If so its probably unsuitable for your engine but you may be able to flog it on.
gazz81
Apr 15, 2016 18:06:41 GMT
Its probably just a pattern replacement. The GP1 Cam will require stiffer valve springs and uprated rockers, not sure if it would even work properly without? You would notice if it was an uprated cam on a standard carb as it will be lumpy as hell at idle.
Apr 15, 2016 18:26:35 GMT
Apr 15, 2016 18:28:19 GMT
Mine was marked up on the end where you have the HH marks
