gavs1
Managed to scratch that itch and got me self a swede brick, Mucho loves it. She,s a 940 se 2.2 auto estate on a m plate, I've so far repaired the lumpy idle. And now after replacing some bulbs in the dash I have an srs light and an arrow facing up showing up. Needing to erase these proply, so a what do they mean ?b how to clear them, ? Any info will be gratefully received
shin2chin
After having a quick google - The srs light is the Supplementry restraint system, basically airbags and seat belt pre tensioners. OBD to read the fault code or you can try disconnecting the negative battery terminal for for 30 minutes. Reconnect the negative terminal and drive the car. Do this three times. If the SRS light re-sets things are good. If not, it is time to replace the SRS sensor and the power module. The arrow light means 4th gear (overdrive)is engaged. The most common component that fails in the overdrive system is the overdrive relay. The relay is located behind the ashtray on the relay block. If you remove your ashtray, pull the plastic trim piece from around the cig lighter and remove the screws from the storage tray under the radio, it will be easier to access the relay. The wire that runs from the gear stick switch down through the floorpan to the transmission can also get chafed. You may want to take a torch and look up near the back of the transmission where the wire comes out of the floorpan, If that wire is damaged then it can ground out against the transmission case and cause the vehicle not to shift into overdrive, but 9 times out of 10 it is a failed overdrive relay.
gavs1
Mar 27, 2016 16:19:43 GMT
Give it a go but we're is the obd port? Would have thorght it'll be to old for plug in
Mar 27, 2016 23:36:29 GMT
OBD reader will be useless on that age Volvo, the SRS fault will the seat belt tensioner or sensor in the seat base don't go wasting money on modules. As for the overdrive warning I doubt that being an auto it would have OD on 4th.
pop over to Volvoforums for some expert Volvo related answers.
shin2chin
Mar 28, 2016 15:31:35 GMT
OBD reader will be useless on that age Volvo, the SRS fault will the seat belt tensioner or sensor in the seat base don't go wasting money on modules. As for the overdrive warning I doubt that being an auto it would have OD on 4th. pop over to Volvoforums for some expert Volvo related answers. All that info is from the Volvo forum
