Sept 5, 2016 15:00:26 GMT
I think ive sorted it. Making sure the ignition was 100% made a little difference. Then it started playing up again. Right about then, half the fuel shut off solenoid fell on the floor. Id already modified this to be permenantly open as the wire had broken, but the last parts of the body fell apart creating an air leak. Runs great again now
steveg
Sept 5, 2016 18:05:42 GMT
Van look great now it's all back together. The interior you are planning sounds a lot like the six wheeler Transit that was built in the late 70's early 80's. There ws a thread about it on the Transit forum a few years back as someone found it. It was called 3001 and was in Street Machine. I had a quick search and found this thread on Rod's and Sod's with lot's of info. www.rodsnsods.co.uk/forum/whatever-happened/3001-transit-50626
Sept 5, 2016 18:40:41 GMT
Ive seen pics of that transit but didnt realise its interior was like that. I assumed it was all womble skin like all the others. Shame I cant find any pics of the ibterior.
Sept 25, 2016 22:49:43 GMT
First trip away, all good really. Few bugs to work out.
westycapri
Club RR Member Number: 105
Sept 26, 2016 7:32:09 GMT
Awesome, would be good to see some more pics of your set up?
Cheers
Josh
@fantasticmrford 1984 Ford Capri 2.0s 1978 Ford Transit Autosleeper 1975 Landrover Series 111 Dormobile
Sept 26, 2016 17:14:33 GMT
Sure. Anything particular you want pics of?
Its become obvious we need an awning as vans full of wet clothes are no fun.
I am also thinking of fitting either a propex gas heater or an eberspacher diesel heater.
westycapri
Sept 26, 2016 22:01:26 GMT
I haven't had a wet trip away but I'm not sure what's worse a wet tent to pack away or wet clothes. Heating is definitely a good idea. I want to get a propex heater but they are a bit pricy, although does make it use able all year. Failing that if staying in a campsite with electric hook up can get a domestic oil heater for £20-30 and they are meant to be safe in a van. That'll probably be my stopgap until I can afford propex.
Would be good to see some interior pics
Cheers
Josh
Sept 26, 2016 22:06:40 GMT
Hanging sopping wet barbours and dog coats in the van with wet towels on the floor to catch the drips and watching the whole van fill with condensation is no fun!
Ill take some pics but its the same as yours but the tall cupboard has a normal door. I'm guessing yours has been changed for that roller door?
westycapri
Sept 26, 2016 22:26:28 GMT
Haha fair play tent wins! And don't worry about pics thought you may of done something or be planning something interior wise to make it better. Heading up to tideswell, rented a cottage for a mates 30th so should be good fun. Love it up there
Sept 26, 2016 22:33:04 GMT
Interior will be redone but not for a couple of months.
Tideswell is my favourite place. Wife prefers buxton. Hopefully moving to one or the other next year.
Good thing about tideswell is its not at all touristy, that and all the rooks make it quite atmospheric.
Cracking work. Nearly bought a CF myself some years ago. But unfortunately it was total rotten! And definitely beyond help!
froggy
Oct 10, 2016 12:11:33 GMT
Same problem I have with my van is single glazed windows just suck all the heat out that my gas propex can create. I have a set of suction cup Thermo blankets to cover all the cab glass and some pads to block all the other windows at night which works well . I have the nozzle out of the propex pointed at the floor and it seems to do its best work once the floor is bone dry . I just hang wet stuff under the wind out awning and hope for the best .
Oct 10, 2016 19:03:31 GMT
I got an awning in the end and fitted a new leisure battery and a nice durite VSR split charge system with a new fuse box for camper stuff. Its nice being able to trust the electrics at last! I raised the front a little and refitted the old shocks as they were adjustable. My nice new shocks are too soft and made the van very bouncy. Having all sorts of brake issues. Front brakes kept unadjusting themselves so I re designed the adjusters but they also judder but only when braking from high speed. Feel great at low speed. Went away again last weekend too
Oct 10, 2016 19:07:36 GMT
eternaloptimist
Oct 11, 2016 19:27:08 GMT
You've done a brilliant job with that.
Oct 11, 2016 21:04:40 GMT
Thanks. Enjoying driving it, it drives well. Enough power, easy to dive, handles well, comfortable. Just a bit noisy.
Got plenty of little niggles to sort before ill be happy but its getting there.
I want it to be as usable and trustable as a new van. I want to be able to drive it anywhere, anytime without any niggling concerns about what might break.
Dez
Club RR Member Number: 34
Oct 11, 2016 21:52:31 GMT
Front drums by the sounds? Take the shoes out and file a chamfer/lead in on the front edge of each shoe, it'll stop them grabbing. It could also be contaminated shoes or skimmed drums that are a bit too large for the shoe, but try the filing trick first.
Last Edit: Oct 11, 2016 21:54:04 GMT by Dez
Oct 11, 2016 22:10:22 GMT
Front drums by the sounds? Take the shoes out and file a chamfer/lead in on the front edge of each shoe, it'll stop them grabbing. It could also be contaminated shoes or skimmed drums that are a bit too large for the shoe, but try the filing trick first. That was my next idea too. Today I found the front wheel bearings had settled a little and had slight play. Removing that has reduced the judder a reasonable amount. I also found the servo is leaking vacuum yet again so that cant be helping. The modified adjusters are at least working correctly now. The brakes can/will be excellent but I van see why people get sick of them. There performance is either great or terrible, no inbetween, and it only takes the slightest issue to send them haywire.
Carlosfandango.
Now with added Suffix B Range Rover classic - another bucket list car acquired.
Oct 11, 2016 22:47:27 GMT
Love the van, love the sight hounds ;-) A man with excellent tast it seems.
Enjoy!
CFD
1966 Fiat 1500 fast road/race conversion 1967 Porsche 912 1968 Fiat 124 Spider 1973 Range Rover Suffix B 1993 Series one Discovery 200TDI 1997 Jaguar XJ6 3.2 sport 2001 P38 Range Rover 2.5 TD Brace of Triumph bikes
Oct 11, 2016 23:13:53 GMT
