was carefully removed from a fully working escort silvertop zetec efi with the alloy inlet. this has the pats loom in here and transponder and both the black key and also the red key I have as well so should work just fine mated to a EFI silvertop zetec.
complete engine loom to get you running , ECU as well (BALL type) so everything there to get you running and have additional security feature of PATs as well as all you would need to do is removed the key from the transponder and it would not turn over until it sees it.... very very handy.
only asking £30 posted for it all! even got fuel lines in there as well from the alloy inlet!
