Sadly the time has come to sell my 1982 Porsche 924 2.0 N/A. It shows just over 10k on the dials however some of the history I have would show it is actually 110k ( the mileometer only goes to 99,999!)
As the car is a project it comes with no MOT due to the fact the car was bought by me last January with a view to get her back on the road, she has been off the road since 2001.
All electrics work as they should even the rear hatch demister, the tape deck even has a Motown compilation still in!
Unfortunately over time my fleet has expanded and I no longer have the time or space to finish what I started.
Below is a list of the things I have completed so far:
New ignition coil
Replacement distributor with new cap, rotor and vacuum.
New HT leads
Replacement 5th injector
Replacement cold start valve
Replacement air flow meter
New rubber mountings for coolant bottle and air box
Replacement fuel distributor (old one was gunked up)
New fuel pump (external)
Replacement internal fuel pump
New fuel pump to accumulator pipe
New fuel filter
New injectors
New air box clips
New sunroof clips
New sun visor clips
New fuel pump relay
New bonnet gas struts
New water pump
New thermostat
New cam belt kit
New auxiliary belt
Bad bits:
There are not too many and I don't think this car will take much to get going.
Needs badge panel fully welding and painting to match - just tacked on at the moment.
Some resurface rust on two arches
A few marks on the paintwork - may t cut out some of these
Dent on bottom of drivers side rear quarter - not huge but being honest!
Fuel relay needs bypassing to run pump, will need looking at but doesn't affect usability as it is.
Fuel pump needs to be mounted fully
Timing needs to be set up fully, engine turns and splutters but seems ok
Seats have split on their bases
Carpets have changed colour a bit (should be dark brown) I was going to use some die to sort this.
Only one key and No glove box key - however this is open.
Aerial needs connecting.
For the asking price I will include a brown dash in much better condition than the one in the car and also a replacement centre console to replace the one in the car which has damage.
Also I will include the gear gaiter to replace the tatty existing one.
The car has lots of receipts from my short ownership and some from the previous ownership, I have also completed a DVLA history compilation that documents the entire cars history from the beginning - I will include this in the sale.
I'm sure for someone with a bit of knowledge and time the car could be ready for its MOT relatively quickly.
Only selling as I need to prioritise my projects and make the wife happy!
£800ono
Contact me here or pm for contact details. Viewing is welcomed/encouraged
Images of the 'bad' bits are as follows:
New ignition coil
New HT leads
New fuel filter
New injectors
New air box clips
New sunroof clips
New sun visor clips
New fuel pump relay
New water pump
New thermostat
New cam belt kit
New auxiliary belt
Bad bits:
£800ono
